The rules I follow:
Decide what tool to use depending on the wood and application of that wood.
We have some serious HARD wood (actually called iron wood/ 'ysterhoud' that actually sinks in water), on the farm we use a diamond tip bench saw using considerable pressure to cut into smaller pieces to fit in the fireplace. Takes less then a minute with the diamond tips usually. If we do it by hand it has taken us up to 30 minutes to cut it into manageable pieces. An axe, depending on the design and who is swinging it 10-20 minutes. Now there is no way I will ever use ANY folder to try and baton through that!
The only times I have used a folder or fixed blade, even a nice thick one to baton is to make kindling. KINDLING and fire preparation.....now that is something that is important. If you get enough finer sticks and grass that you pick up as you walk, from 5mm (a lot of those) then slightly larger and larger and larger, you can burn a log without need to baton through it. If you think you have enough kindling.....get three times more!
On my original statement: Decide what tool to use depending on the wood....well...I wont use a fixed blade or folder on 3/4 of the wood here, because they are hard as can be...and would not risk my knife that I can make kindling with to get a fire nice and high, generate a good bed coals, and pile larger logs onto that.
That is also how I was trained in scouts. You start small and work your way up. Lots of posts going on about emergency situations, but heck. Dont risk the tool you have in order to look cool, do what can safe your life by using common sense and thinking. There are more then one right way to do anything.
Why do people die in the woods Bob? Because they did not do the one thing that could safe their life, thinking. (out of the movie The Edge)
So to answer
How often do you really get around to batoning wood in the wild?
No.
.... do you guys plan on batoning through wood?
Not with a knife, only cut pieces to make nice fuzzy sticks to start the fire.
I will use an axe to split wood.
Do you bring your own baton, or do you figure you'll pick one up as you go?
No need, either an axe, machete to chop dead pieces off the tree and then make fuzzy sticks to get a lot of kindling.
BTW. Here = African Savannahs and semi arid Savannahs.
It might differ from people that live in wood type environments.
I am pro axe for what I have seen in Australias wood chopping competitions when my grandfather showed me what they could do. Here is a google search for videos (
http://www.google.co.za/search?hl=e...ion&btnG=Search&aq=f&aqi=g1&aql=&oq=&gs_rfai=). The axe is a great tool designed to split timber. I use it for it others might not. I have seen some great axes in Damascus that can shave, even met people that are so strict about an axe that they will flip if the head of an axe is stuck into the ground and so damaging the edge. An axe used in a propper manner (just like a knife) can be the safest tool in any environment I believe. If a fool uses the tool like a fool anyone can get hurt.
Those are my thoughts.
