- Jun 30, 2005
So ,in all my Military and civilian life.........Thoughts ?
What branch of service, & what did you do in the military where you got to make campfires?
Batonning alone is not going to get a fire started. You’ll need tinder. If you make a one stick fire you will need to scrape the inside, and it better be dry. I would be out sniffing for the means to make a bundle, not relying on wood shavings. You can split small kindling [batonning] until the cows come home, but you have to get the matchstick kindling burning when all is said and done. Making a fire when you actually need one is a very serious business. It must not be rushed and it must not fail. The pressure is quite intense.
You know ,Lite the Barrel and Stir.What branch of service, & what did you do in the military where you got to make campfires?
I rarely find myself in a survival situation, so I am not sure if I would baton in that scenario.
So ,in all my Military and civilian life I have never been anywhere in the world where there wasn't various sizes of wood ,bark , and a mulititude of tinders with which to easily make a fire . Other than a wet situation where you need to get to the core of the wood to get to some dry stuff . I addition I don't get the fire stick thing ,dulling up a blade that you might need to process game for example. To me its all video marketing of knives . I'm sure ill get blasted here which I could care less . Thoughts ?
When you examine force and duration and direction on knives in typical uses, to include stabbing, and chopping....
and then compare the shock loads, direction of forces applied to handle, and blade (mostly opposite to normal use), also impact velocity of edges, and etc..
The only wonder is that knives hold up as long as they do....they certainly will have internal stress accumulate out the whazoo, be greatly fatiqued, and will fail quite sooner..
If not in original owner's hands, then in the hands of a subsequent owner...
I think several hundred years from now, the reputation of knives made today will be severely tarnished by high failure rates, the bushcraft craze maybe forgotten, and this generation accused of entering a dark ages of knife manufacture, .......
and wisdom of the time saying all knives from this timeframe are suspect, and best left as wallhangars...
Batoning has been a traditional method of kindling generation for many hundreds of years or more, and billhooks are typically used for the task to the point where it's not uncommon to see billhooks with their spines mushroomed from being repeatedly struck by steel hammers. Despite the fact that nearly all of these billhooks are hidden tang construction, you don't tend to find truly broken ones. Because they're used for wood of an appropriate size and grain.
Going to let my video speak for me
