- Aug 19, 2011
3. I'm not discussing possibilities. The learned that in the woods cleared that up, it's why I added it, to make it clear.
6. Yes I said exactly that. Many hikers who can pack a tool that performs many tasks do so. It's not uncommon at all and extremely uncommon for people to make a reason to carry extra tools.
8. I do way more than that with it.
3. I know the mechanics behind how wood splits. That's why if I notch, I use a shallow hollow ground blade, I even have a deep hollow grind blade I use time to time, both 1095.
4. My long blade chopper is 2" shorter than a BK9 and 1/4# lighter. Go back far enough and you will see me posting it chops better than a BK9. It also has a shallow hollow grind and I know how to sharpen it.
7. That's why I carried a Glock field knife.
I don't expect anyone to do it my way. I don't expect anyone should convince me I need to carry an axe or hatchet. I don't expect anyone to do it my way. I do expect people to understand I can get the same end product without an axe. I know I can, been doing it a long time. Doesn't mean a single one of us is right. I just like hiking (light). I like a fire to cook or warm up with. I prefer to split wood with a knife I have with me and not carry an axe or hatchet. That's pretty clear how I do it. I'd love to hear how you do it on your multi night over night hikes though, so please share.
I can agree with our position and am glade to see that you are willing to make allowances for other peoples experience, it was the earlier position that only a single configuration was correct that concerned me so much. That being said I fined my self having to politely but strongly disagree with your position that a knife alone is more versatile then an ax and a knife together. I am surprised by your choice of a hollow grind for chopping I would have thought that to be a delicate. I have seen some speed axes use something similar but they seemed impractical I will have to look in to this. Do you have picture of this blade I would be interested in the proportions of the grinds.
As to my kit it depends on were I am going, as that there is no one answer to all environment. I do not have one load out for every were that I go with the exception of my 3 finger EDC that dos ego every were with me but it is not a stand alone knife. as a general rule If I am in low lands I cary a light machete and a companion knife (3-4.5" with a 3/32-1/16" thick blade) if I am in the hills I like a tomahawk and a companion knife. When hunting I will some times take a 5" blade to help with butchering, and maybe a dogwood skimmer (altho I have used my 3 finger for so long it is what I use 90% of the time). We have gone far afield at this point perhaps we should start a new thread to talk about the best blade to cary to a given terrain?
To return to batoning I will speak the bushcraft blasphemy and say I fined very little reason to use the technique. When things are wet I find that if there are 3-4" logs then there are also stick and branches. Even after days of rain if I look for example in the ley of a tree or rock or such, or for branches hung up in a tree, or branches dead but still attached I have plenty of wood to start a fire and that small fire drys larger bits of wood and I add that which makes a bigger fire that drys more wood and so on. This may not be the case in the wet north west and it was not case the rain forest were we did fined batoning in helpful. In general with the exception of joinery for making structure I fined batoning of limited use. When moving light I do not build large permeant structure and if I am setting up a base camp I bring wood working tools with me. This is why I prefer to fined a knife that cuts efficiently (I see that as the first purpose of a knife) and then chose my battening technique according to the blade I have. It seems that this thread has wondered far afield of the original question of what knife is good for batoning? I would say one with a blade that is sharp on one side and has a handle will baton just fine as with so many things it is how you use the tool, one should ask "what is the primary purpose of this tool "then look for traits that support that task knowing that if it sharp it can be pressed in to almost any cutting task.
