Cliff Stamp
BANNED
- Oct 5, 1998
Sure, but not all work which requires such a profile is misuse.SethMurdoc said:i meant to imply that because swamp rat knives are capable of taking that kind of use, they are good for people who misuse knives.
As you get more experience you can make due with a smaller cross section of blade, generally you do this by changing method, in most cases this however lowers efficiency.swamp rat knives are good for newbies (because they are strong and can take the abuse while the person learns how to use the knife without inadvertantly damaging it)
For example take a newbie and ask him to clear some hard branches from a low light tree. He will likely take the knife and attempt to sweep the branches off. This is one of the hardest things you can do with a knife.
The newbie will do this pretty much irregardless of the knife because he doesn't know how difficult it is and thus will break a large amount of knives in doing so.
Someone more expereinced will check his knife for the necessary cross section and if it isn't there either try to cut the branches off individually taking care to avoid lateral stress, or break them off with the spine or a stout stick.
However, if the experienced woodsman does have a knife which can do it, he will do it, and sweeping them off is many times over more efficient than beating them off.
It simply allows a wider scope of work. Good for people who just like to poke and prod with no real point, sure, but sometimes these things have a point.
-Cliff
