Tai Goo
BANNED
- Apr 7, 2006
The only place my Nazel used wood was under the anvil and to wedge the anvil in. It looks like your anvil is a separate piece, but if it sits flush with the hammer base it should be easy. My anvil actually had to sit into a recessed hole on about 18 inches of solid oak as I recall. The anvil was like 2-3 tons, and there was about 3 feet of reinforced concrete under the wood part. I don't think you need the wood, but if you use it 3/4 plywood probably isn't going to do much. You might want to put a recessed spot for a more substantial wood base directly under the anvil... but there again, probably not necessary. If you are worried about shock to the concrete, maybe just a hard rubber pad under the anvil or something like that.
