While the grind lines and bevels are not "laser straight" on my 9, they are pretty dang close. So much so that it took some pretty fine measuring to discern any flaws.
The Hellion looks pretty gimmicky IMHO, kind of like the "Hawke-chete"...what's his fascination with that modified Tanto-ish point anyway?
I don't like it, no sir, don't like it one bit...
The edge on my BK-9 was not centered in any way with the spine: I've rarely seen a knife that is that far off, but given the good initial sharpness I was willing to forgive even that. Of course not all of them will be as bad as mine... Harder to ignore is, when looking down the spine, seeing it is not lined up to the handle, and instead veers off to the right in a very obvious curve... I have a feeling that is more intrinsic to the way it is heat-treated...
I would agree the grinds of the BK-9 are not the worst. Moreover, considering the price, the out of the box sharpness is something most high end fixed blade custom makers coud learn something from... It's just that a curved blade spine is a bit beyond what I can take. Nothing to do with its function I'll admit.
The value of the Tanto point is in fact the only real advantage the "American" Tanto point design ever really had: Bringing more mass closer to the tip, making a better chopper, while still retaining the option of some puncturing ability... By having a blade that grows wider towards the tip, the Hellion maximizes the mass advantage. Too bad Tops had to go with their usual blunt grind...
As for no photos of the Bk-9: Sorry! The BK's rough black finish picks up a huge amount of wood crud, not a big deal, but until I really cleaned up all this embedded wood, I was not too inclined to spend time photographing it... Here are some pics of it when I compared it to the Jereboam (you can already see some of the wood crud clinging to its side): Interestingly enough, despite a similar weight, and the Bk-9 having its point of balance much further forward of the hand than the Reeves (1.6 inches vs 1/3"!), they still chopped the same: I attribute this to the thinner edge the hollow grind gives to the Reeves:
The difference in handle confort, when chopping, between the Reeves and the BK was just huge in favour of the hollow handle... Like the BK-9, the Hellion also had a very slight handle vibration with the original factory edge, but that disappeared when I re-profiled it, so sharpness affects handle confort noticeably! I think the handle vibration could be a feature of full tangs: Another reason why they are a bad idea...
The Hellion is now quite a bit sharper than the BK-9, but it took a power tool to get there, and you can see the broad grinds... Sheeesh...
Gaston
