Would you mind sharing how you got it that way?
Sorry. Didn't mean to make you wait. Had to run out for a bit.
The scales were getting a bit worn so I took 'em to work. I work for an automotive paint company and have some pretty cool stuff available. The coating is a semi gloss, very dark gray paint with whats called a texture additive. Its used to repair plastic bumpers and such but if applied thin, it gives a grippy finish but not so coarse as to take skin off.
As for the blade, I used patience and a lot of it.
I have a Craftsman benchtop belt/disk sander with the 4" X 32" belts and a 6" disk. I used the belt and a 320 grit to take the finish off. Being careful not to over heat the blade. It leaves a "satin" finish that is serviceable and allows for quick touch-up if it ever rusts.
For the polishing, thats where it got interesting. I converted the 6" disk to a 6" 3M Hook-It II system. Simplest terms - from glue on paper to velcro backed sandpaper ranging from 80 grit to 3000 grit. This also allowed me to put on what is called an interface pad. its a foam pad that goes between the disk and the sandpaper making the sanding disk soft. Usually used for sanding contours. It allowed me to Sand the blade with progressively finer paper while keeping the heat down too.
The whole project was an ongoing, little bit at a time, experiment.
It was fun. I'm debating on whether or not to give my Howling Rat the same treatment. What do you think?
Thanks for the compliment.
Chris
