I like doing Business with Alpha Knife Supply (AKS) Fast Reliable service and he ships USPS Flat Rate Boxes and you couldn't ask for a nicer knowledgeable person to talk to on the phone if you have questions about his products. His web ordering page is Real Time so you can see what is available when you place the order and not suffer that "Oh sorry that is on Back Order" phone call.I admit I tend to get very annoyed when I order something and it does not arrive when I have been told it would. I put my steel order in on Friday of last week and opted for 2 day delivery. Monday I called them and they said it was leaving for shipping that day and will be here Wednesday. it's now Thursday and no steel. Has anyone ever used this company? Tool Steel Service of California.
What is an "online" reliable steel provider that is known for getting orders on time and has a large selection?
I would call them and tell to cancel the order... if this is how they do business, I would rather they not have my money.I admit I tend to get very annoyed when I order something and it does not arrive when I have been told it would. I put my steel order in on Friday of last week and opted for 2 day delivery. Monday I called them and they said it was leaving for shipping that day and will be here Wednesday. it's now Thursday and no steel. Has anyone ever used Tool Steel Service of California?
Okie405, are you still in OK?
If so, where abouts?
An order placed on Friday (unless after hours) should ship Saturday, Monday at the latest.
There are plenty of knife-centric vendors (especially the ones that support this site) that will do anything they can for the passionate folks that make knives.
I know you are new to this, but linking to a non-paying vendor is not allowed. I would suggest their link gets removed so you don't catch an infraction.
The chip breaker files leave a finer finish and still move metal fairly efficiently.
The key for efficient filing is getting your work positioned correctly. You've got to stand for sure, and you want the work about belly button height.
Use your body weight to bear down on the work and push with both arms and legs. Lift up slightly on the return stroke.
To square things up or flatten them out switch to draw filing. Turn your file perpendicular to the work piece and grasp the file in both hands. Push down on each side evenly then pull towards you. Lift and repeat. This is a much slower process than regular filing but it will flatten out wavy surfaces and you'll be able to square up the spine etc. much more easily.
Get a half round and various sizes of round files for inside curves.
Personally, I'm a cheap skate and would just buy a couple files. That being said, both the spindle sander and the 1x30 could be used later for working on handles and the like after you get your 2x72...
On the topic of 2x72's buy the best one you can afford, get the direct drive, variable speed with at least two tool arm holders. If you have to save up for two months instead of one, do that. As so many people on here will say "buy once, cry once".
Yes, there is a difference. Pulls systems have inherent weaknesses, namely vibration and a small amount of power loss. If you are dead set on those two, go with the bader.
I've never used either but from everything I've read on this forum, the Baded is a FAR better machine. KMG has a reputation for having awful quality control and abysmal customer service.
Ask Matthew Gregory on this forum about the KMG and he'll give you an earful!
I built my own, but were I to buy one, I'd buy one from Oregon Blademaker on EBay or save up some more money and get one from Northridge Tool. Or if I had more money to play with a TW-90, one of the local guys near by has a couple TW-90s and man are they sweet!
ETA: get a VFD, it's well worth the money!
1. I would rather send blades off "Clean" no discoloration that way you know that any problems(probably won't be any) but the HT facility can inspect clean surface prior to heat treat to look for any areas suspect to cause a crack on quench.
2. Any decorative file work should be done before HT and should not cause any warping. I prefer a little bit thicker 0.020-0.024 is about right the closer you are to .020 the less you will have to deal with after HT.
3. I like A2 at 62HRC that is a good tough blade that will hold an edge and be easy to touch up in the field(I hunt Elk and that hide will kill most anything less tough) I can't get through a whole Elk with one knife way to much work so I use 3 sharp knives and still might have to do a little touch up sharpening I want the edge to go through like it's butter...but that's just me with lots of knives
A. Your grind being a recurve is a tough one to grind just starting out...Thought I would throw that in there in case you struggle with getting it symetrical. You will need to work the "Inside" curve at the edge of the belt instead of "Flat" against the belt like on an normal flat grind or saber grind it's a bit tricky. If your son is going to do file work on that pointy sticker stop a good half inch from the tip or he will have trouble with grinding the tip away and lose the filing work.
