This is for people looking to get into the knife world, maybe looking for a good EDC (every day carry) at a reasonable price.
I don't claim to be an expert, just have been through the pain (and considerable expense) of buying some knives that weren't really what I was looking for. I'm trying to save people some of that pain (and potentially, expense). Also, I'm dealing with non-assist, non-automatic folders. I consider the others toys--neat toys, but still toys.
Things I consider:
1. blade steel.
2. blade length and weight.
3. lock.
4. handle material
5. serration
6. look
7. make
1. blade steel:
Imho, you should be looking for one of a few types of steel...this assuming you aren't going for a custom blade (damascus and other hybrids).
S30V - pretty much the best steel out there...very hard, holds an edge, difficult to sharpen
CM154 - similar to S30V but even harder to sharpen
D2 - great steel, easy to sharpen, not quite as hard as the above types.
Aus8/10 - still very good steel...avoid Aus6 imho.
There are a few corrosion resistant steels that are also worth considering...one is used in the Spyderco Salt and another is used in some Benchmade Griptilian clones.
Anything other than the above, I would avoid. Are they horrible? no. Will they cut things? yes. They just seem cheap to me...
2. blade length
imho, if you are looking for a tactical blade, the longer the better...something in the area of 4". For non-tactical, urban, concealed utility knives, around 3 inches is sufficient. Check with your State regarding knife laws. There are people who think the lighter the better...I disagree. For me the knife doesn't have to weigh less than 2 oz. I have some heavier ones that I carry without even noticing the weight.
3. lock - getting to the heart and soul here...frame and liner locks rely on bent steel that slides into place behind the blade to lock it in place. Do they work? yeah. Do I like them? NO. I hate liner and frame locks and will not buy any more of them. The Sebenza 21 is generally considered an excellent blade...and it is! great steel, craftsmanship...frame lock...part of the frame moves in behind the blade based on the fact that it is slightly bent. You have to straighten that piece of steel out to close it. It is sound..I just don't like them. I have to admit that most of the top combat folders and big names use liner or frame locks.
Locks I like...Benchmade Axis..great lock...SOG Arc lock, lock backs (many Bucks use lock back).
4. Handle material - a lot of handles are G10, some are plastic...I haven't met a handle material that I wasn't ok with. G10 seems a little more solid, but the zytel stuff or fiberglass seem just fine.
5. Serration..imho, any blade that you're going to carry every day as a utility knife should have partial serration...for seat belt cutting, any kind of sawing, the serration is nice. Rescue knives are often fully serrated and don't have a stabbing point.
6. Blade shape/functionality/look - really a personal preference here...blade shapes can offer some different functionality, but the bottom line is, do you want to cut stuff and is the knife supposed to be a weapon. If it is, you need a stabbing point.
7. Make - lot of great knife makers out there...I am currently partial to Benchmade, Spyderco and Buck. Ideally, I would like to see that the knife was made in the US.
My current blade searches are for S30V or D2 blades with axis or lock back locking mechanisms, partiallly serrated, around 3" (not looking for a weapon--for that I'd suggest Striders, Zero Tolerance, some Cold Steel blades, the Gerber Applegate Fairbairn is nice--liner lock though I think) I consider the blade shape, functionality and look after I find something that fits the above critieria.
Some current suggestions: I absolutely love the Spyderco Native S30V version for somewhere between 55-70 bucks. I also like the new Benchmade Bone collector line and the Harley Davidsons for some different, more classic looks all in the $100+ range that I've seen. Also, the Buck site has
a customizable knife build system that can set you up with a classic hunting folder in S30V steel with a lock back for around 100 bucks...handle is configurable for different looks.
Hope this helps you skip some of the junk I bought early on, and still keep the fun of discovering WOW, this is one nice knife...
K~
Things I consider:
1. blade steel.
3. lock.
4. handle material
5. serration
6. look
7. make
1. blade steel:
2. blade length
K~
