- Mar 18, 1999
Forging versus stock removal. What a subject!
Stock removal is actually a more modern approach to making a blade. Even with pattern welded steel, which is becoming more and more readily available in bar stock (a la Damasteel and some others), stock removal is becoming more and more the choice of many makers.
Man has been forging blades for many, many years. There is a lot of legend and lore concerning the making of a blade. From the Norse bladesmiths to the Japanese makers, some of what we have heard is true, some is not.
(Now, this is where you say to yourself, this CLWilkins fellow has gone off the deep end, but bear with me).
There is a lot of mystique around forging a blade. Way back when, there were the "prayers" and "chants" associated with bladesmithing..In days before time pieces and other methods ot measuring elapsed time, a practiced and repeated chant or prayer would be a viable method for measuring "soak time" on a piece of iron...knowing that you should start the chant when the iron is say just turning red and then remove it and quech when you are done with the prayer could allow enough time for the carbon to go fully into solution while you are "praying"...Medieval man was not stupid...he was just not aware of the whys and wherefors of things.
No, prayers and chants aren't necessary, I was just making a point on one of the traditional aspects of forging. I do stock removal and I have been known to say a chant or two in the shop. Especially the time when I got a little too careless around the buffer!
Forging is the more "traditional" method and the maker actually has more control over the finished piece. I don't believe I have to explain to this forum what is meant by "more control".
Which is better? No one can truthfully answer that question. It depends on the application AND the heat treat.
CLWilkins
CLWilkins
