Square_peg
- Feb 1, 2012
I think I own something like 9 grinders. I haven't counted in a while. They're useful. But I enjoy filing an axe.
The main reason i bought this HF belt sander was to help me speed up making my hatchet and axe handles, I'm far from an expert. I enjoy using a draw knife, and spoke shave,and sand paper, even a piece of glass every now and then. It makes me appreciate what people before us had to go through just to make a axe handle. My Grand dad was a black smith for the railroad. I sure wish i'd had the opportunity to be around him more and learn a lot of what he knew.
Where a belt sander is the cat's meow is on wood. If you screw that up or take off too much there is no harm done. Bring out the next piece and start over!
With steel if you get the angle wrong or sand off material merely to remove an irritating chip you'll very quickly discover the blade is 1/8" shorter. To accomplish something like that with a file takes considerable effort and you're much more likely to inspect your work as you go and not get too cocky about stock removal in the first place.
Messing up a piece of wood can be a costly mistake in both time and material. Anyone that has done much wood working has experienced it.
Another "piece of wood" is just around the corner, a clean and stamped axe head from the 1920s (etc) isn't.
Just from what I've learned on this forum, a hickory stave is much more rare than axe heads.
So Garry, you are telling us that there is nobody on this forum, or who drops in on this forum, that would ruin an axe head with a power grinder? I will have to think about that one!
I guess I have just not run into the people who can draw the temper on an axe with a file.
Most of these steels are tempered at 400 degrees give or take about 50.
Axes are more likely tempered at about 500 degrees.
