So I passed on Gerber's Armor, and picked up a Vex. I was in a hurry, so I just bought it.
It has 2 major flaws:
1. The ball detent sticks out further than the width of the washer. That makes the blade really tight, and the ball starts to wear down because it is jammed against the blade so hard. I fixed it by sanding down the inside of the G10 slab under the moving part of the liner.
2. The pivot can't be tightened "just right." The blade is either really tight when opening, or if the pivot is loosened enough to fix that the blade wiggles left/right when open. It is caused by liners that aren't perfectly straight as well as the common blunder of a blade/washer thickness total exceeding the width of the spacers in the handle. Both can be fixed carefully. Mine says "first production run," so maybe they will have this figured out eventually.
Then a few observations...
The washer layout is kind of goofy. One side has a brass washer, and the other side has a combination of a teflon and whatever that gold-colored metal washer is on top of it. It's weird to have different metals on either side. The teflon one is likely included because teflon is a little bit squishy, and can help hide poor manufacturing tolerances. But in this case it isn't enough to make up for the error.
The G10 slabs feel good, no splinters hanging off on the outer sides. The edges are only slightly buffed though, so it has a square feel to it.
The liners are about as thick as a Benchmade or Emerson, and along with the blade have a dark gray finish (the blade is not actually black). Looks good.
