Yes precisely, just like Cliff has observed happening to the edge of a certain severely thinned out blade made from S30V that is know to be run relatively soft.Like crumbling as it is sharpened, before it actually forms a burr you would notice?
Your are not addressing the issue. If they are that fragile, they should hardly be able to form a stubburn burr. I think we have all had the experience that there are some burrs that are NOT simply drawn off by running the edge over some wood or plastic. Obviously they are irregular but I don't see how that would affect the issue at hand. Cohesiveness does not imply regularity.Not exactly. If you look at burrs under high mag you can see they are very jagged, often highly irregular. They are deformed to plastic and just barely holding on, which is why you can easily scrape them off with your finger nail.
Well, if these steels can deform that easily, especially considering the lower strain rate at smaller cross sections, thin edges made out of such a steel should not simply fall apart on you, as you have experienced yourself. Or are you saying that the edge geometry of even thin edges is that much thicker than a burr, that the strain rate is sufficiently larger.those steels need a lot of force to abrade but have little ability to resist the force and thus they deform without getting cut.
Finally, as I said, while the highly alloyed steels may exhibit similar problems, my personal experience with bad burrs has been mainly with low carbon content stainless steels, which are not overly hard to abrade. Sure they are often really soft. I don't know, it is hard to judge for me by feel whether a soft lower end HC steel like 1060 or even 5160 is really that much easier to machine than a soft low carbon stainless steel like 420J or even 420HC to account for the difference in burring.
Just compare the following: I know from experience that 420HC can burr much worse than S30V. Nominally they were supposed to have very similar hardness, but lets say the 420HC slipped a few points. to may be 56-57 while S30V may be assumed to be 59Rc. Now the 420HC is significantly softer, but S30V is significantly more abrasion resistant. Which one would you have predicted to be worse. By your argument it would be a difficult call, yet in practice they were not even close in burr formation.
Sorry, everyone. I realize that this thread has been badly hijacked
