- Aug 26, 2010
some people ONLY collect all the variations, colors, etc of a specific model
and some models have 10-20 variations
Straight Handle Steel Heart II
Kowing that the knife is clean and does not have residue sap on it is the issue ... prepare food with any blade which has any dirt or sap on it and you will get the "runs" ... happens all the time in the military with guys using coated bayonets which are hard to tell if they are clean ... the old SLR bayonet was my learning curve on this ...
In the field I always use a satin finish for food prep when cooking and use boiled water to clean the blade ... doing a gralloch or skinning game and preparing it I am happy using a coated blade ... it is handling/cutting the food after it has been cooked that you need to be careful ... or using a knife on none cooked food like bread or fruit ... cooking will clear up the risk of a bit of dirt on a carcass ... but slicing meat off a cooked carcass or cutting cheese is where problems start ...
Becareful if you have a tool steel blade where people tell you to do a forced patina ... these can be as difficult to tell if the blade is clean as a coated blade ... I experimented with these and then found when cutting white cheese that the cheese was tainted by stains ... not worth the risk of a dodgy stomach in the field ... nothing is worse ...
A seperate food prep knife is the best arguement for carrying a second blade for "survival" purposes ... and the extra weight is usually very little if you make a sensible choice.
I wonder if one of my Emerson or Spyderco folders would suffice as a secondary food prep blade. I suppose not... because of all the cracks and crevices that would harbour bacteria.
What's up with the muliple versions of the same knife?
Think less cut more= happy ending![]()
Ever gone on a trip and wished you had planned better? The trip I'm planning won't be for fun. I definitely do not want to be in the middle of it and finding myself wishing I'd taken the time to plan through the details when it was possible to do so in a calm and reasoned way. Weapons, tools, mil spec clothing, lighting, solar charging, water purification, warmth, shelter short term rations, specialized training etc etc etc. Each and every one of these "details" has, is or will be getting days, weeks or even months of attention.
Basic 7 paired with a good, solid folder.
At 1/4" blade thickness and weighing 12 oz with Resiprene-C handle, the Basic 7 is lighter and as strong or stronger than anything else in the 7" blade range, long enough with enough forward balance for efficient chopping/batonning but not so long that point work is awkward, has the best of all Busse ergonomics IMO plus insulation from cold/vibration/electrical shock, and a standard asymmetrical edge grind which is one of the strongest, most efficient cutting edge geometries and the easiest to sharpen in the field.
Yeah, but that trip was called a deployment and I didn't get to do any planning for it. Trips I have more choice on, I can't say that I ever have, no matter what happened that didn't fit the plan, but I learned a lot for next time. Reading all of those prep plans really makes me wonder how the native americans and so many millions like them in other/past cultures could possibly make it without all of that stuff.Get a good knife, gun and a few other simple necessities/tools, learn what is most important in order to use common sense to adapt and the rest will work itself out for as long as you are able. After that, it really won't much matter.
Must try a Basic 7 at some point :thumbup:
