- Jul 30, 2006
I'm moving to Fiji for an extended period and would like to take an EDC folding knife with me. Obviously Fiji is very humid with salty air yet you might be surprised at just how quickly things rust/corrode there. Short of getting a dive knife I want the best corrosion resistive steel for a folding knife. In researching the following steels: 440C, Aus 8, CPM-154, S30V, S35VN, M390 and 14C28N, it seems that the best for corrosion resistant is the 14c28n.
My conclusion comes from my research and some assumptions, and I have very little experience or knowledge about knives so I am asking a question rather than making a statement and hoping some of you with more knowledge can educate me. The reason that I believe the 14c28n is best is because if I look at the composition of all these steels and compare them to the known highly corrosive resistant dive knife metals like H1, N680, X15TN I see a pattern where the Carbon content is low, the Chromium is high and there is a bit of Nitrogen added. The 14c28n has similar properties whereas the other steels do not.
Any input is appreciated.
H1, x15tn, and n680 are the top three in that order, as far as edge retention, reverse the order. Besides those three the others you mention should all do well, I know m390 is very corrosion resistant as well. If you go with h1 serrated models will be harder at the edge and give you noticeably better edge retention compared to the plain edge.
What Michael said.
H1 is the most corrosion resistant, but holds an edge the least well. Serrated models are said to be better in edge retention.
N680 holds an edge well and is very corrosion resistant, but is not as corrosion resistant as H1. Benchmade's Lone Wolf series has a lot of models in N680, or did last time I looked.
