- Sep 14, 2006
Somthing I dont have, I have a SA, and 2 striker's
Ah, just for something different. I getcha.
Andy
Those who carry 1911 know how often people ask if they knew their gun was cocked...lol.
One of the more interesting DA/SA pistols was the Daewoo DP-51.
A P99 seems okay until you fire or even handle one of the older non-plastic Walther 9mm pistols. I have a P5 and a P99. The P5 is the most accurate 9mm I have ever fired. In contrast, I really don;t like the P99. It replaced the P88, whihc cost about 3 times as much, but may very well be the best DA 9mm of all time. The problem was that the full size P88 had an MSRP approaching $1500 back in the early 90's!!!! My second favorite is the Sig P220. I have one in .45. I would love to find one of the old .38 Super models and see if it could be converted to 9 x 23 Winchester.I really like the Sig 220, it is probably my favorite DA/SA. I also really like the new HK45, I have fired a Walther P99 and I was very impressed with it. Like it has previously been stated go to the range and try a few models out.
Sig DA triggers, well, any of the DA/SA triggers have never really been a problem for me. I guess I must be doing it wrong...
That is only part of the Sigs I dislike. I've had a 220 and a 229. Both were used so I don't know what they went through prior to me.IF you get a Sig, get one that has their new "SRT" (Short Reset Trigger)
It removes much of the complaint about the trigger reset.
(altho, the long, gritty, hard pull is still there !)
You may also be interested in the HK45. The DA trigger pull is heavy but smooth. The trigger reset isn't bad either. If you carry the 1911 concealed you can carry the HK45. The HK45 is a little thicker than the 1911, as to be expected. HK45 also allows you to replace grip panels to make the pistol fit your hand better.
The HK45 is freakin' huge! It's a lot *lot* thicker than a single stack 1911.
Just saying'.....
