- Apr 13, 2004
Polished convex. Just because it's so easy for me to apply with the leather belt and green compound on the power belt sander. Personally, I haven't seen anything a toothy edge could do that a polished edge could do just as well. DPS depends on what size the knife is; smaller blade typically gets lower DPS.
To clarify a little bit: Since it is so easy for me, I will always start out with the highly polished convex edge that I apply at home when I have all the time necessary. Nothing wrong with that. Once in the field, if I need to re-sharpen, it is then that much easier to do. I carry a small strop, a 2-sided diamond stick (fine/medium), and a 2-sided ceramic (fine/ultra-fine) that I can then use to re-hone the edge as necessary.
The diamond stick is probably unnecessary, as I don't usually need that level of edge work in the field, but I carry it more for the time when a mistake is made and the edge really needs help (hitting a rock by accident, etc.). But it doesn't weigh much, and Murphy will always strike when you're least prepared for him.
