This was interesting to say the least
yup, found out about it from bladeforums a few years back.Didn't think anyone else knew about fluid film ha
Seriously?the best edge retention in generally will come from H1 serrated steel. or REally old sharpened a bunch of times H1. just saying.
Seriously?
SheeshI believe he's joking, though I may be wrong haha. Who knows.
That's not how work hardening functions.the best edge retention in generally will come from H1 serrated steel. or REally old sharpened a bunch of times H1. just saying.
Out of these steels which will hold the best edge? s30v D2 n680 154cm m4 20cv
This is false.Just so you know...having to do with that H1 serrated...
Sal has stated, on this forum, that nothing he has produced will outcut the H1 serrated.
It is not heat treated but, work hardened means. The more you sharpen the steel the greater the edge's hardness becomes. THe serrations due to the grinding process vastly increase the blades hardness. You come away with a hard edge that tapers back to a softer steel further back. Giving it the best of both words in regards to blade edge retention and durabllity. Theres several interviews with Sal or Eric discussing the properties of h1 and how it has out cust any steel they have tested. You can also just call up spyderco and ask them- they would be happy to explain it for you if you dont belive me.Really? H1 isn't even heat treated is it? By work hardened, they are referring to the process by which it is produced aren't they? H1 serrated is usually claimed to be above VG10, I wouldn't put it even close to the same category as super steels, or even S30V.
This is false.
Sal said that nothing they have "tested yet" has out cut the H1 serrated edge.
Keep in mind that this testing was done prior to th Maxamet Mule being available, and he has yet to speak on Maxamet vs Serrated H1.
Hi Mora,
H1 is not heat treated in the traditional way. The steel is work hardened in the manufacturing and processing of blades. Edge retention in the plain edge config would be about the steels that you listed. It does sharpen easily, and gets very sharp. In the serrated config, it will stay sharper longer than anything we've tested to date.
sal
I am going to get a benchmade griptillian. Mainly cutting wood and rope. I am narrowing it down to 20cv and M4.
