Best ferro striker?
I've always used hacksaw blade that the teeth have been ground down a bit(ala Chris Janowski)but I've seen lot's of others.What's the most effective striker to use?:)
I also use hacksaw blades but I like to square off the back of my knife and machete blades and use that. I have never failed to get a large volume of sparks with the back of a blade. Some of my can openers on my various SAKs and multi-blade knives work great for this too. Mac
The squared off spine of my knife, or a hacksaw, but the knife throws better sparks and is easier on my hands, as I don't always get it going first strike.
cz75b: What is Sandvik Coromant?
hacksaw blade here too. I get the best sparks when I dig in the squared point at the end blade into the middle of the rod. It lights tougher barks because the spark appears larger and hotter when I do it that way.
I recently cut down a kershaw outcast which left a sizeable hunk of the tip. I am now using that as my striker as well as a mini "back-up" blade for my PSK. It worked out well because all I had to do was cut the corresponding amount of the sheath off to house the tip in and I can attach my ferro rod to that, one nice tidy package and there is still enough sheath left to use when I get around to finishing what I started with the outcast.
Hacksaw blade over here... I sometimes use the back of my knives just to prove it can be done but so far my F1 and RAT-7 don't do as well as the piece of hacksaw. They are bigger and more prone to send all my tinder flying.
I am about to get two BRKT's and I guess both of them have a ferro rod holder for the standar Light my Fire ARMY model... how about those strikers? I mean... if they are sold as strikers they can't be that bad, can they? (as you can see I don't own any... I just bought some 10x100mm blanks on eBay)
Mikel
Hacksaw blades are cheap and efficient, and light. But the best striker is the awl on a Vic Farmer. Great strikes, much more comfortable and controllable than the hacksaw piece. Allows a nice, full grip versus the 'pinch' you give the hacksaw.
I use hacksaw blades, sharp spines on knives, and different things on my leatherman (like the file).
As a side note, I recently got an army model, whereas before I only had scouts. And woooo! I can get much bigger sparks that land on what I'm lighting and continue to spark. I can consistently light things with one good strike with the army, whereas the scout took me a few tries.
i agree with the hacksaw blades... they throw a mean spark and are cheap and easy to find...:thumbup:
a while back i scored a scott gossman firesteel striker, in O-1... this thing is awesome... it throws a huge shower of sparks....:eek: scott normally doesn't put an edge on these, but he made an exception for me... it sports a wicked sharp semi-scandi convexed edge....:D check it out... this thins is just too cool...
you can also see my damascus wedding ring, really well in this pic....:D
I square off the edges of SAK tools (nailfiles, insode of bottle openers) and these work well for me.
I am having trouble with a fixed blade spine however. What is the best way to square off the back of a fixed knife blade? There is a section of a small case hunter I have that I'm trying to grind down. I've tried with a dmt bench type stone on a flat surface, holding the knife spine as perpendicular as possible (freehad) and grinding awy. Metal is being removed, but I'm not getting it very square. Any tips? Maybe I just haven;t ground away enough material? It is stainless steel if that matters, but the SAKs are S.S. as well. Come to think of it, I never reall got a hacksaw blade squared off enough to work as well as everyone says they should, so I must be doing something wrong with my method.
Thoughts and comments appreciated. MODS - If this is too close to a thread hijack, feel free to delete. :o
Funny this thread came up.
I just bought a BSA hot spark yesterday and I could get decent spark but not enough to set a napkin on fire easily. So I used a knife with a high carbon steel and nearly scared myself with the amount of sparks it made. Needless to say the napkin went on fire on the first try.
That's freakin sweet! My favorite tool is the spine on my Koster Bushcraft.
Where'd you get the ring? I was thinking about Ti vs damascus for my wedding ring.
Newadventure: Use a metal file, the sharpening stone will take forever and needlessly wear out the stone.
A sharp piece of flint works real good, also the worthless bottle opener on a leatherman kick.
My survival kit has a CRKT Wrangler with a firesteel attached. Thing is comfortable on the hand closed and throws tons of sparks.
OT- Snow- I love my wedding ring set in Mokume by Delbert Ealy! Now I just have to wait until July to wear it (but fiancee loves her rings too- I can just look at her engagement ring if I need a fix)
