Best mini-PSK knife?
CSG
While I've made a little Altoids tin kit recently, I really like Ritter's PSP and have one in each vehicle. I've stuck a SAK Classic in each but that's not the best knife for even the simplest outdoors task.
Today, I got a new Buck 110 from LL Bean and it came with a Chinese made mini-Buck lock back. It fits perfectly but is not available for separate purchase.
I'm looking to replace the Classics with a single lock back blade of a similar size. What can you recommend to fit the Ritter PSP or Altoid tin?
Maybe a Buck 325 Colleague (frame lock!)
or....
If you have room, a Spyderco Dragonfly with the clip cut off. This would be the best. Great egros if you needed to use it for heavier choirs.
The Ladybug looks interesting. Buck has a couple small lock backs like the 325 and 505 (sort of a mini-110 but with a drop point blade).
All those knives are too big, grunt save for the JK Tin knife. For this use a folder is probably better (bigger blade). I wish I could do business with JK but he doesn't take credit cards or PayPal.
I've got a BRKT PSK and it seems like it would do well in a PSK tin. Small enough to fit yet big, errr...sizable, enough for probably any task you might ask of a small knife. Definitely a choice to consider :thumbup:.
Might also consider a Buck Hartsook with the sheath modded to be flat.
bark river psk
The Sheath is Designed to be used in the Otter box, used as a Neck KNife or can be dropped into a pocket. The Cut out in the Side of the Sheath allows it to be wrapped with Fishing Line or Cord. Specs: Overall Length:5.150 Inches Blade Length:2.175 Inches Cutting Edge Length:2 INches Blade Steel: 12C27 @ 58rc Blade Thickness:.090 Inch Weight:1.75 Ounces
next to mikro canadian
A Buck Smidgen or Hartsook is surprisingly useful for it's size, but a SAK like a Huntsman will fit in an Altoids tin and offers even more utility.
there are a lot of good PSK style knives out there... here's a short list..:)
-BRKT PSK knife
-BRKT mikro slither
-BRKT trickle
-Buck hartsook
-Gossman PSK
-Koyote PSK's
-Tops mini harpoon
-JK tin knives
folders:
-Sdyderco ladybug
-SAK classic
-Case mini trapper
The upcoming yellow Spyderco LadyBug with non-rust H1 steel is IMHO the best companion for the Ritter PSP. It would also fit in the pouch.
I would recommend a Spyderco Dragonfly. Fits nicely inside an Altoids tin. With a lanyard that fits over the pinky, it makes a great knife for its size.
