averageguy said:
6A is the softest steel I've ever used except for Pakistani pot steel.Seriously, you're better off with 420HC.
420HC is more comparable to AUS-4. 420HC used by Buck for example has a carbon content of 0.4-0.5, AUS-4A is 0.40-0.45, AUS-6 is higher at 0.55-0.65. AUS-6A has a higher max hardness than 420HC, not lower. The other alloying elements are either identical or they overlap, aside from the AUS series having a small amount of vanadium for grain refinement and wear resistance.
STR said:
Honestly I don't see anyway AUS6 would be preferred over 440C for any reason.
It is tougher, more ductile, has a finer carbide size, better machinability and grindability, there are various applications where this is more relevant than wear resistance, specifically in the knives I noted for which I would prefer it, assuming of course I had to pick between it and 440C. Note some makers are switching from steels like D2 to steels like S7 for the same class of knives I mentioned I would switch from 440C to AUS-6A, is the the same reasoning. Of course some makers always used those types of steels and favored toughness and durability over wear resistance for fairly obvious reasons.
I always considered AUS6 to be a steel in the same league as the old "Surgical Stainless" knives produced for years that were bottom of the barrel steels used in cheapy knives.
Read Verhoeven's work, specifically note how he compares 440C vs AEB-L, now note the composition of AEB-L/12C27 to AUS-6 and see how it fares with respect to the materials data he provides. As well read Landes commentary on 440A vs 440C and which one he prefers for a knife steel and why. For some direct user work, see reprofiling Sodak has done on D2 and watch what happens to the usefullness of its high wear resistance at low angles for wood work. And of course check the work Alvin and Mike did over 10 years ago on rec.knives noting what happens to coarse grained steels at low angles.
patrickjames said:
It is really false, as noted AUS-6A isn't inhernetly softer than 420HC, as a direct example Phil Wilson runs his customs in 420HC at 55 HRC, CRK&T runs their AUS-4A at 55/57 HRC, thus even AUS-4A isn't softer let alone AUS-6A. There are also lots of knives which are well respected which are that soft and softer such as Randall's O1 which is 55/56 HRC, their 440B which is 56/57 HRC. Reeves also runs S30V in his large blades at 55/57 HRC and for a rather extreme example, Jerry Fisk tempers his personal knives to 52 HRC, far softer than even the AUS-4A that STR accuses manufacturers of "milking the public" with. Not to mention the vast amount of goloks, parangs, machetes, bolos, etc. made out of steels typically at 45-55 HRC.
-Cliff
