- Aug 26, 2010
What is the absolute best blade steel used in a folder that's not a one off custom
i'm looking for the ultimate in edge retention
I second the heat treat.
My s30v lochsa acts vastly different than any of my CRKs s30v.
I think it also depends on how you use the steel and what do you presume edge retention is.
If you use it to cut hard objects or come in contact with steel or other hard materials you will want a semi softer steel like Crk s30v (58 rh) so it will not chip.
If you cut mostly tape or paper like materials you will benefit from a hard steel like zdp-189 (68 rh)
And that just scratches the surface about edge retention.
I saw in another forum where they tested the HRC values of Spyderco's CPM-M4 in the Gayle Bradleys (not sure if it would be the same for the Military), and they were testing up pretty high around the mid-60's (65-66 iirc), I'll try to dig up a link. I've also found that the Speedforms that I have (I & II) have very good edge retention, although I use the Speedform II much more than the Ti one.
