The 110 might not be a bad choice but I would take either of these two knives over it, the Kershaw 1050 and the Schrade LB7+.
http://www4.gvsu.edu/triert/kershaw1050htm.htm
The LB7+ has stabilized wood scales. I've seen lots of broken scales on the 110, never seen any on the LB7+. The LB7+ has a stainless steel pivot pin, the Buck has a brass one. Lots of guys like to loosen up the blade so they could flick their 110 open. Hard to do with a stainless steel pin. And the steel is 440C. And this particular one is amazing at holding an edge. Don't know if the newer LB7s are as good though. This knive is probably 15 years old and has butcher many deer. Yeah it is a Buck Imitation but Schrade at least didn't make a half a$$ imitation.
But I will still take the Kershaw over it as a "survival" folder. The spine is thicker and the blade is tougher. This is a knife I wouldn't be afraid to hammer on if I was trying to dig the heart wood out of a stump to get some dry tinder to start a fire or chop saplings for a shelter. The false edge on the 110 and LB7 would be less amenable to this.
We all know that in a real survival situation you have to make do with what you have. But I think that point is irrelevant to the "what if" question I originally posed. Sure, any ol' knife will HAVE to do, if that's all you have. That's really just stating the obvious. But, as the boy scout motto sez, "Be Prepared." And that's what "what if" survival scenarios are all about, anticpating the future and being prepared for it.
The brain IS the most important survival tool we have, but that also means we should use it BEFORE we end up in an unfortunate situation so that if we have to "make do," we have the best advantage we can plan for. A little forethought can save your life. A lack of a little forethought and too much complacency can lose it.
Hoodoo
The low, hoarse purr of the whirling stonethe light-pressd blade,
Diffusing, dropping, sideways-darting, in tiny showers of gold,
Sparkles from the wheel.
Walt Whitman
Hoodoo
Walt Whitman
