- Jul 22, 2009
Here's the thing:
I'm expecting a fixed blade in full flat ground S125V coming in. It will be between Rockwell 64-66 and has 12.5% vanadium content. Thing is, I'm not sure which cutting task would really make this steel shine.
I found S90V and CTS-20CP to excel at cutting cardboard of nearly all variety, though I suspect the 1/2" thick pieces will do some damage to them. Thing is, those two would typically be around Rc 60-61, whereas S125V will be considerably harder at Rc 64-66. I'll still test it on USPS cardboard boxes, though the cardboard I cut at work(usually put on the top, bottom, or middle of a pallet stacked with items) seem to be a reinforced variety that feels like cutting through 3 layers of the postal office cardboard even though it's the same thickness or thinner. So I'm a little concerned about possible chipping in the long run.
I found ZDP-189 takes a nice razor edge despite the carbide volume, which makes me think Hitachi might not be using 1st generation PM to make the steel. I rarely chip ZDP, though I'm not sure of the relative toughness compared to S125V, again because it might be a higher generation PM steel(any confirmation on this would be appreciated), which would make it tougher than an early generation PM of a similar makeup.
3rd generation PM steels like Elmax and M390 seem to be good general purpose blade steels good for pretty much anything outside of large choppers and tactical prybars(though Elmax is probably good for that too). Takes a razor edge and holds it a while too, more wear resistant than S30V and more corrosion resistance too. Even at Rc 62 I found M390 tends to roll rather than chip. Sharpens up fairly easy too and takes a mirror polish well.
Thus far I've determined that toughness is good for chopping where the blade and edge are subjected to hard impacts, especially against hard objects like other metals. I would define "edge stability" as the ability to take and retain a finely honed edge. Hardness seems to increase edge stability and wear resistance, as well as resistance to deformation. Grain refinement increases toughness, ease of sharpening, and edge stability.
Hardness and edge stability seems to be good for most kitchen tasks where you cut fruit, vegetables, and boneless meat. Toughness for chopping bones and frozen meat.
Wear resistance is a bit tricky given that it can be made useless without adequate hardness(S30V from Benchmade) and toughness(ceramic blades).
I'm sort of wondering if S125V isn't something that's just shy of being a ceramic blade. Thing is, I was never that crazy about ceramic blades in the kitchen. I prefer push cutting, and given that ceramic can't handle a thin edge and can't take a fine edge either, it didn't really appeal to me.
At RC 64-66 I'm guessing I probably should put a low angle on the edge, though it might only be good for the light kitchen cutting tasks due to the lack of toughness from such a thin edge, and I'm not sure if any kitchen task actually demands high wear resistance from a steel.
