How much wear resistance contributes to edge holding depends on the type of material you are cutting and the other properties of the knife. A few general rules of thumb :
1) as a knife gets softer, wear resistance contributes less, because the edge rolls readily and can't stay crisp enough to allow any wear
2) as the material becomes very abrasive, wear resistance starts to be a factor
3) as the material starts to become harder, wear resistance becomes less of a factor (because it tends to roll the edge rather than wear it)
So for example considering cardboard :
Here blunting is roughly half wear and half deformation, so to determine the effect of increasing wear resistance you would calculate :
(50*(1+x)+50)%
where x = the increase in wear resistance
So if you doubled wear resistance you would get 75%, which would mean the knife was only 75% as blunt after similar work, a decent enough advantage.
However, if you tripled the wear resistance you would get 63%, which shows you that increasing it dramitically doesn't gain you nearly as much as some tend to suggest.
If you go insane and increase it by ten, you just get ~55. So you can see that useful increases are 100% or less.
So don't get too excited about wear resistance *without* hardness, regardless of the hype.
Ken, how about sticking to debating the facts and just using logic, are you actually going argue against :
1) custom makers with oil + cryo can get higher hardness than just air (this is basic materials science)
2) large batch oven soaks + tempering induces thermal mass issues (this is basic materials science)
3) single blade testing is vastly more precise than any random sampling done (this is basic statistics, you are comparing populations to sampling inferences)
4) production companies have to build their blades to looser tolerances because they don't know who is using them, from novices to experts (this is basic common sense)
As for the companies looking out for our best interests, sorry, P.T. Barnum doesn't have a customer in me, try to sell that somewhere else, Newfoundland wasn't founded by people that naive.
Look around and you will find lots of production and custom makers openly stating that they routinely offer products with a lower functional ability just to meet the popular demand which is often *not* based on performance, choosing steels and/or designs which will sell not because of how they work, but how they appear or are thought to work (the whole concept of stainless being "superior" to carbon steels [a large portion of the public think the stainless marking is a direct sign of quality] for example sells a lot of knives even though it has no basis in fact)..
As for S30V being tough, it has no functional advatnage in toughness nor flexibility nor strength over ATS-34 in the like, as per the actual spec sheets by crucible and as by blades I have used and broken, and seen broken by others.
Is it a decent stainless steel, sure, It can get very hard (~63 HRC), and at such hardness makes a very nice light utility knife, giving better edge retention than ATS-34, and has a nicer heat treat according to a few custom makers. At <60 HRC it offers little to no functional advantage over ATS-34 that I have seen personally (outside of wear resistance which as you can see in the above is more hype than fact).
I have a Military in S30V, its a great folder. However would I get really excited about it vs VG-10 in the exact same blade - no. Would I want it in a large tactical, not even close. I have even used it at Reeve hardness and it still chips too readily.
As for best / worst, as I noted this depends on the knife, so all you need to specific is the knife and how it is going to be used (and what you want performance wise) and you can rank a steel from best to worst, just like you can talk about cotton vs wool for clothes.
Do all of the comments I made apply to all companies, no, as noted some are much better than others (Spyderco and Swamp Rat for example have very high QC and standards of quality). But quite frankly if you think thay anyone who is trying to sell you something isn't inherently biased about its abilities - then Lady Liberty is up for sale, contact me for details (only $9.99 a month, no interest, no down payment).
-Cliff
