spider silk is stronger than steel by weight, and 5 times as elastic as kevlar. I wonder what that would do to an edge if we could get it in diameters comparable to sewing threads.
I agree. While there's no question that hair whittling requires a pretty high degree of sharpness, because individual hairs are made up of multiple strands, fairly coarse edges can whittle hair; what's actually going on isn't whittling per se, like with wood, but peeling away of a few individual fibers of the hair once the edge has "snagged" them.I always found cutting hairs the next step above whittling. A knife that could easily whittle curls off the length of a free hanging hair may not be able to cut it clean off, away from the point of hold. The distance away from the point of hold is another part of the gauge.
A really fine, polished edge can reach levels of sharpness where it actually becomes more challenging to whittle hair, which I suspect is because it cuts so easily and consistently that it becomes harder to snag a few fibers of the hair without cutting through the rest.
"hair whittling" is ghey, very ghey
How so?
IMO whittling hairs is a bit uninspiring compared to more dynamic tests for sharpness.
Here you go on a few more - these are even Oleyfermo approved.
http://www.bladeforums.com/forums/showpost.php?p=3020763&postcount=1
1. it can easily be done
2. it is not a test of a properly sharpened edge, since its possible to "whittle" hair with a burr.
3. the way that you act as if it is setting some sort of "new" standard.
