Cliff Stamp
BANNED
- Oct 5, 1998
Jeff Clark :
Several common grips have one of two fingers ahead of the bolster and work best if the center of balance is at that point. Though yes, on a really thin blade this isn't an issue.
The bolster protects the side of the finger from the back of the dropped blade which will be very sharp on thin blades. As well the high pressure generated on rocking cuts is usually out near the tip when the off hand is used to press down which again is where thicker knives with fully rounded spines can be of benefit.
For other kithchen knives none of these elements are factors and thus you go really thin for optimal performance, filleting, carving, utility and paring knives are generally very thin, boning knives are generally thicker for stiffness.
In regards to stock thickness and comfort, I noticed the same thing when doing a lot of rope cutting, I was using a thumb on blade grip and even though the Deerhunter was easily more efficient than other thicker blades, they were much more grip friendly than having a ~1/16" piece of steel pressed against the thumb. If I had to do a lot of such work I would readily take something a lot thicker (spine wise not edge wise of course).
For a long time I thought Boye was really off using such thick stock for his blades but now I can readily appreciate the ergonomic advantage for some types of work.
-Cliff
Since the bolster is ahead of your hand it can't bring the balance back to your hand.
Take another look at the UK-60 and you'll see that the top of the handle projects over the blade and provides a more comfortable finger rest than a bolster.
-Cliff
