- Dec 5, 2005
The blade has been heat treated and tempered.
Bing didn't take pictures of the heat treating process as there have been many threads about that already.
Bing uses a digital oven for accurate temperatures, and quenches at 1475 degrees, in Parks 50 quenching oil. The temper is set using 3 cycles at 425 degrees.
From Bing;
I measure up the back spacer and am getting .160" thickness
Now we calculate the bearing thickness .0625" in the counter bored pockets of the liners, minus .050" depth of counter bore.
Leaves us with .0125" of bearing on each side above the counter bore pocket.
I allow .0025" for the bearing track in the bottom of the counter bore pocket
I want to have a blade thickness on .140" when finished
The digital vernier caliper indicates a blade thickness of .156" before final surface grinding
After final surface grinding and flat sanding to 800 grit, the caliper indicates a finished blade thickness of .140"
More to come later today.
From Bing;
