Bk11 for trade with curly birch handle and leather sheath
Feedback: +0 / =0 / -0
One Becker bk11 knife with curly birch handle and coating removed
One R JOnes leather sheath
One Plastic Molded sheath for the Bk11 allthough the knife does not fit there anymore due to the New Handle
clIHpvBRpkRu0JTkdJc48Z9fQ9hq71xNmbAJBc4GdV4=w680-h510-no
IYmCPgbz93HQKm_WV_Q06aOgW6FMJ2pJ29UI5gy-Nuc=w680-h510-no
knife has been used but it is in perfect condition, the edge of the knife has been convexed for better edge and cutting capability. The handle is made in curly birch and finished with true oil
I also upgraded the sheath to a leather one that is made by Robert Jones ( beo-wulf is his user in ebay) and it fits like a glove
this are the original specs of the knife that stand true to this knife except about the skeleton handle ( that now has a longer more confortable and beautiful curly birch one)
and the sheath that I include is a Leather one ( I will also include the molded plastic one if you like)
Ka-Bar Becker Necker Knife # BK11
Ka-Bar Becker Necker Knife # BK11 #bk11The Becker Necker Fixed Blade Neck Knife BK11 is the quintessential neck knife, that is ideal for everyday and tactical applications.This Knife from Becker Knife & Tool has been updated with 1095 CroVan steel, a redesigned sheath, and marked with the new BK&T KA-BAR stamps for a knife that will perform year in and year out. The BK&T Necker Fixed Black Blade Fine Edge Tactical Knife includes a plastic injection molded glass-filled nylon sheath and 550 cord, so you can easily reach for your knife when needed. This Becker Fixed Knife is made with a Fine Edge Drop Point Blade that will provide you with better control and edge retention. The Becker Knife and Tool Flat Grind 6.75in Necker Neck Knife has a skeleton handle that will provide you with an amazing grip on your knife.
Features:
Updated with 1095 CroVan steel
Redesigned Sheath
Marked with the new BK&T KA-BAR stamps
Black plastic injection molded glass-filled nylon sheath
550 Cord
Designed to work with the TDI Metal Belt Clip, #1480CLIP
Easy on and off mounting to a belt, in a boot, or on a tactical vest
Specifications:
Steel: 1095 Cro-Van
Blade Type: Fixed Blade
Blade Thickness: 0.165" (0.42 cm)
Blade Length: 3.25" (8.26 cm)
Overall Length: 6.75" (17.15 cm)
Weight: 3.2oz (91 g)
Grind: Flat
Edge Angles: 15 Degrees
Handle Material: Skeleton
Blade Shape: Drop Point
HRC: 56-58
Sheath: made in Taiwan
Stamp: KA-BAR Becker
Pocket Clip: N
UPC Code: 617717200113
Made in: United States United States
here are some reviews by other users
“How does the knife perform?” you ask? It performs superbly. It is easily the best knife I have ever owned and has yet to let me down. The durability of this knife allows me to use it with confidence. Users of the BK11 claim to use it to field dress game; I for one tested this knife in a way that many do not. I tested this knife by cutting down a tree. Yes, a tree. I did this by cutting a 360 degree wedge in the tree and then pushing it over when it was thin enough. If the stuff it the fan, I’m confident I could construct a shelter with this knife if needed.
Tree with 360 degree wedge cut in
This knife surpasses what I require in a knife. It has done me well and I’m sure it will well into the future. It is truly a small knife that handles some big jobs. For the price and what it provides you cannot go wrong.
