trevitrace
- Jul 21, 2013
Cerakote is impermeable, isn't it?
It may be, I really don't know. I'm pretty sure Cerakote isn't considered a DLC coating though.
People often praise DLC for extra corrosion resistance, when that is actually false.
That was my understanding. So, is there any functional benefit to dlc covering a blade or is it just for appearance.I hope people realize that DLC coatings are pourous and do not help with corrosion resistance.
What I'm trying to figure out is how someone with an ACTUAL DLC coated blade can manage to scratch it. I've literally pounded dlc coated knives through steel, cut many, many boxes, etc. and the only thing I can find that leaves major permanent damage is the swarf from sharpening with either sandpaper or stones. Hell, cutting and batoning into concrete barely left a couple of scratches and that's literally banging it directly into a bunch of compressed rocks. How can cardboard conceivably scratch it? Were there pieces of silicon carbide or something embedded into the cardboard?
I've scratched a true DLC coating many times.
Also, FYI, cardboard is often made under a process that uses SiC. So yes, often times cardboard has "hidden abrasives".
Then maybe it wasn't true dlc and instead was some kind of TiN or TICN coating.
I like the American Lawman package so much that I carry it often but I would prefer an uncoated version.
No, Rockstead phased out TiN and TiCN years ago. I know about the knives I'm using...
Maybe the mirror polishing the blades prior to coating has something to do with it...
Or... maybe I just use my knives to the point of scratching them.
You have no idea what I use my knives for.
If you're using your rocksteads to carve mortar out of walls, kudos to you. But don't go acting like cutting marshmallows will scratch real DLC. At least give a disclaimer. "I scratched actual DLC by firmly scrubbing the bevel against a diamond cutting wheel." You don't know what I've used knives for either. I think we'd probably have mutual respect for what we both do so there's no point in bickering. I've abused the crap out of knives the same as you. I've never seen actual DLC have permanent damage unless I was purposefully trying to screw the knife up or got entirely too careless. But even then, whatever it was that scratched the DLC would have most definitely scratched an uncoated blade. Hence why I don't really care for DLC but I can see it being good for others who don't like to mess with maintaining or playing with their knives too much. Tool steels with some level of corrosion resistance, but not enough to be really stainless, I think would be great for DLC coating for the average person who wants a tool steel's performance without the maintenance.
I like for my fixed blades to be coated, to help with corrosion, since I use my fixed blades outdoors in the woods 90% of the time. I like for my folders to be uncoated though. I did just buy a coated folder, so go figure.
