- Sep 9, 2018
Hi guys, So as Im new to knifemaking I have been practicing making blades from low carbon steel. Im not expecting anything from them just getting used to shaping etc.
A while back i bought a plate of damascus patterned steel from aliexpress (no idea what grade of steel it is) and thought id have a go at making a knife from it as I had run out of other stock.
Anyway this stuff was so hard a file skated across it and wouldnt cut it! I managed to grind it into a knife with an 80 grit belt (took a fair bit of time!). I took it to work and threw it on the hardness tester to find it was between 65-70 HRC! As you could imagine I have had a hard time drilling it.
Im trying to finish it with a handle but cant get through it with a drill bit. Im presuming its stainless as the drill bites and cuts then seems to work harden the material and then refuses to cut deeper than a millimeter. I have tried faster, slower, lube, dry and with a cobalt bit and it wont budge!
Any tips on drilling this stuff? Is there a way I can anneal it? I have a small heat treat forge but its nothing special.
Took the advice of you guys on here as well and sacked off the jig, been doing freehand grinds all the way this weekend. Pic of the offender below:
