Out of curiosity--other than a guide--what does this offer that a HF 1x30 belt sander and a selection of Klingspor/3M micron belts doesn't? Maybe I'm missing something here, but the HF belt sander is dirt cheap and works pretty well as far as I've experienced.
Benefits I see are size, portability, and ease of changing belts. A 1x30 grinder would be cheaper, more stable, and the belts last longer.
Do any of you guys know the length of the belts used? I'm wondering if I can get them locally.
On Amazon, it says they are 1/2" x 12" belts. They sell replacement belts but it would be much cheaper to get the belts elsewhere.
I'm reviewing this thread after a little googling and it looks like we should be searching for "micro-mesh belts"
http://www.bladeforums.com/forums/showthread.php/787582-Extremely-Fine-Grit-Belts
I was told they are standard 1/2" x 12" belts -
the 6000 grit is supposed to be specially made for them.
I have also just posted in the Gallery:
Photos - Blade Show 2011 Pt.2
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://UnknownVT.multiply.com/photos
Gentlemen, will this sharpener work for blades up to 10''?! I have a lot of large choppers that need to be sharpened, so I am really thinking about pulling the trigger on one of these sharpening systems. Thanks in advance for any help.
Thanks for posting these pictures and comments from the Blade Show Vincent, it was a pleasure meeting you.
It was quite an honor to have Ken Onion come by the booth and speak so highly of our sharpener. He is a real class act.
I just thought I would chime in and answer a few questions that have popped up.
We do have additional belts on our website: P400, P600 and 1800 help to bridge the gap from P220 to 6000.
Our test lab avg. is 50 sharpenings per set of belts and the tool comes with 2 sets.
You may find cheaper belts, but they will likely not last as long or they will run very hot.
We tested every belt we could get our hands on and put the best of the best in the product box.
The sharpening guides (20° and 25°) are intended for novice sharpeners and to help with the learning curve.
Without the guides it is quite easy to create any angle you desire and still get a perfect and super sharp convex edge.
The 'triangle' frame of the belt is 40° - hold the blade straight up = 20° Tip the blade toward the belt for a 15° edge or whatever you wish.
As for the belt going into the edge on the left side, our design engineer Dan did all of the math and engineering to ensure this is not an issue (notice how the belt tensioner is at an angle?). The edge is sharp, the bevels are even and the surface pressure onto the belt is controlled by the sharpening guides and belt tension.
This is not simply a belt grinder, this tool has a lot of engineering behind it.
