- Oct 2, 2010
Here is my letter to Steve Shackleford, Editor of Blade magazine.
To the Editor of BLADE
Introduction:
I am Stacy E. Apelt, and have been a reader of Blade magazine for over 20 years and have been making knives since 1961. I have technical background in metallurgy, and chemistry, having worked in research for VA chemicals ( formerly VA smelting) in the 1970's.
I am currently the moderator and advisor on Bladefourms.com Knifemakers Shop Talk sub-forum. Bladeforums name - Bladsmth .
I have been disappointed in the articles you have been running by Ed Fowler for quite a while, but lately his information is a disservice to knifemakers and your magazine. His self-proclaimed superiority and science is egotistical at best, and totally false in many cases. He has publicly admittedly that he has not made a knife in over a year, but posts articles about his "knife Making" skills, testing, and research. His version of metallurgy is so flawed that any person who has only moderately read on the subject will see the problems in his methods.
Most of his articles are just promotion of his personal theory on metallurgy, of himself, and his school.
His recent article in the January 2012 issue is case to point. It pulls the reader in with "The Cure For Blade Warp"....but is an article on Ed Fowler. It goes for two pages, ending in "To Be Continued".....without any information on curing blade warp.
Mr. Fowler constantly refers to his laboratory testing and unknown metallurgists who back his theories, but never posts any such information or names the labs or people doing the tests. His only mention of any others is Rex Walter and Doc Daugherty. He constantly reports that his methods produce far superior blades, as tested by these two, but never posts the actual tests or results or methods that they were obtained. I am not sure, but believe they work with him at his school.
His claims of metallurgical science are often totally false. Case in point is his constant mention of the "memory" of steel.( referenced in the 2012 article). His claims that "Every hammer mark and thermal event is forever recorded in the memory of the steel" ( direct quote from the article) , and only his "special" process can conquer it, is insulting to metallurgists who have spent lifetimes in the study of steel and its properties.
Steel has no permanent "memory" of past events. Every time the steel passes Ac1 in a heat treatment and converts to Austenite, nearly all prior states are erased and a clean slate starts. If Mr. Fowler's premise was true, the steel would have been ruined at the steel mill, and the damage made worse in his forging and grinding.
Another instance is his claim that placing his blades in the refrigerator overnight can produce a large gain in toughness and hardness, as well as reduce grain size. The conversion of retained austenite in the steels he works ( 5160 and 52100) is a minor issue ( only a few %), and would not happen until -105F. I know of no commercial home freezer that reaches that temperature. Grain size is set at temperatures above 1350F, not at -32F in a freezer. Grain size is re-set each time the steel heats above the Currie point and cools below 1000F.
His claims that his processes , which he will teach you at his school, is going to produce a blade with super fine grain and many times superior to all others is pure hype,..... and insulting to the thousands of bladesmiths reading your magazine.
To wrap this up, I understand that different smiths will have different methods.
I understand that different smiths will disagree on some metallurgical principles as applied to bladesmithing.
I agree that Ed Fowler has a right to his opinions.
Where I disagree is his right to use your magazine to spread his opinion as hard cold fact, when it clearly is false.
I disagree in your running articles claiming all sorts of knife making and testing from a man who has admitted he does not make knives any more.
Final comment:
Everyone is entitled to his own interpretation of metallurgy science....but no one is entitled to his own metallurgical science.
Sincerely - Stacy E. Apelt, FSA Scot
hi stacy
i have decent metallurgy knownlogde background. i do have years of heat treat experience in both theory and actions. i have not worked with ed fowler, not even heard of him until i readed this thread this morning. so i think i can give my opinion in a nuture state. you have been a good advisor and a very helpful person on bladeforums, and i do respect your right of quenstioning other people's claims.
but here is something i must disagree:
i am from china, and i have no chance read any ed's aricle about "memory" of the steel at the blade maganize. but from my experience i learnt that sometimes there is sort of "memory" in the steel. i don't know how can i explain this correct in english. but steel does acting "memorily" or "inheritance" in some situation. its too complicated to explain everything in detial. so i will use a few examples just to state the fact in certain situation.
(1): 20CrMo steel austenitlized at 1250°C in a vaccum furance, holding for 10 hours to form a very large grain size. then oil quenched to room temperature, polish, take photos of the grain boundary. then the steel was slowly re-heat up to above ac1. took photo again. and found some of the grain reformed back to almost excatly same size and shape before. it happened again after repeat heat back up to ac1. so in this situation, it seems like the steel "inherited" things happened before. the common theory believed this is caused by RA that remain at original grainboundry. it act as nuclearation for austensite to form up when reheat to ac1. thus cause this kind of "inheritance" reaction. so less RA, less chance this kind of memory will happen. and it more likely to happen when use induction furance with a very fast heat rate. or the very slow heat of a vaccum furance. the midium heating rate usualy have less chance cause this kind of "memory". cryo treatment or carefully controled heat rate can avoid this type of inheritance.
(2): steel in martensite state is cold rolled at room temperature, cause significant lines of dislocation and subgrainboundries. then reheat up back above ac3, quench again. take photos and found the original subgrainboundry caused by cold roll is "inherited". and grainsize is refined due to recrystialization. very interesting fact is this kind of inheritance can be forgoten after several quenching from above ac3. and the structure can be "reinherited" randomly by more quenching. just like genetic can be hint inherited pass several generations.
(3): annealed steel in its balanced states is cooled rolled to a x%deformation at room temperature. heat up and quench at above ac3. similar things happens.
the excat reason and possiblities that can trigger this kind of ferrous "memory" react are many, and the metallury studys done on this field is still not enough to explain everything. and most of times this "inheritance" thing react unpredictable. but there are already plently of heat treatment used to benifit from this memory nature. i knew factories using the example (3) to product leaf spring for extra tensil-strength gained from the heat treatment. i am not sure what mr ed fowler did to his steel, but we can't denie that there is a chance he is benifit from this "memory" nature.
also, cryogenic treatment might also have a chance to creat finner grain size. i believe it has something to do with the supper fined carbides dispersionaly precipitate from matrix during the cryro treatment. then these very dispersional supper fine carbide will act as nuclearation when heat up just above ac1 during the following annealing. as for austensite, the more nuclearation the finner the grain, more dispersional of the nuclearation the more even of the grain size. again, i do not know how Mr ED fowler did his cryo with his refrigerator. but over here, at northern HeiLongjiang. we got like 2 hours every night at -40f for a month, sometimes it drops to -60f. if i cross that frozen river into russian forests, the cold goes even worse hahaha. so what i am saying is, there always a chance that something can acctrully happen. even though to most of people it seems just impossible.
personally i do not denie any possiblities unless i personally tried it many times and the results tells me no. 10000 years ago at mesopotamia, there was this man who cutted one of his testicle off to find out if it can grow back. eventully he got the answer is No. he then used another one testicle successfully made many children and grandchildren and great grandchildren, their name are Aristotle, Galilei, Newton, Einstein...his family tree lasted to even today. it is said that every single scientist on the earth was decendented from this man with only one ball... so everyone who is reading this now touch their balls, if you find one of them is smaller than the other, i guess you all shares same ancestory lol.
so back to the topic. as i said before, i might disagree some of the statement there, but i do respect your freedom and rights to questioning other people's claim. the improvement of science is base on questioning, otherwise we are still at stong age.
