Professor
- Apr 6, 1999
I got my pre-production mini axis lock yesterday and couldn't help but share here and at the BM forum. It is all I expected and more. I initially noticed that the pivot pin is slightly smaller, but upon investigation found it to be roughly the same diameter as the locking pin. I'm not too worried about it as this is a small, pocketable knife (thinking about removing the clip altogether), and thus is likely not capable of the feats of its larger brother. Fit and finish is excellent; the pre-productions have a G10 spacer and I assume the regular productions will have the Delrin. The clip is a bit smaller, but the stainless liner and G10 thickness is the same. The slightly thinner blade makes for an overall slimmer knife compared to it's brother; I haven't had the chance to weigh it yet but I've heard it's a mere 2.7 ounces which is .2 ounces lighter than the mini-stryker. The frame screws are the standard torx-headed thingies with the treadserts on the reverse side. The clip is "ambidextrousable" like the larger. The stop pin is slightly downsized but is still quite formidable. The blade is partially serrated (I think this was the only way to get the pre-productions, and that's okay with me as they're the standard sized serrations and not the smaller ones like on the mini-strykers) and is individually serialized as opposed to the "1 of 1000" stuff. All and all this is a great little knife that will likely be in the bottom of my pocket for years (unless they come out with something better around the same size which in itself is likely). I've been using it to ream out holes to countersink bolts in my fence gate (good thing I got two of these) and it has done well. I'll give more details on durability later. I think regular production starts in August, as the crow flies. The Professor.
[This message has been edited by Professor (edited 11 May 1999).]
