Bill DeShivs
- Jun 6, 2000
I could be wrong, but I don't think sapphire and ruby are "aluminum oxide." They are harder.
I had the same problem w/ my Rukus using a sharpmaker, I could get it sharp but not sharp enough. Now I use diamond hones for all my s30v blades and it's easy to get them hair popping sharp.
That's nice, gunmike, but which ones of all those steels you mention have larger quantities of Vanadium carbide? Raw hardness of the blade isn't the issue, it is the constituent makeup that appears to be an issue.
Wondered what role heat treat may play in this. I've observed that for a given steel, some companies produce a better blade for a given steel.
I've got a Mini Rukus coming this week. I'm thinking of microbeveling it. I have a BM Activator in S30V that chipped a few times on me. I'd rather not have that happen with the Mini Rukus. Anyone microbeveling their BM S30V blades?
What were you cutting to cause the chip and how bad was it? A microbevel is just one of many ways to sharpen a knife, how were you sharpening the Activator?
Personally I found the 940 to be a bit of an odd ball. To get an angle I felt acceptable for the blade I had to remove the thumbstuds and sharpen it much steeper than possible with them attached. After that it was about the sharpest knife I ever owned or own.
Greetings: The observation that the S30v in a Sebenza did not take as fine an edge as some other S30v blades just jumped out at me. I currently have seven knives with an S30v blade. Two Benchmade 940's, one 930, one Leek, one UK Penknife and two small Sebenza 21's. I have reprofiled and sharpened or just resharpened each of them using Gatco diamond stones and a sharpmaker. I was pleased with the results regarding increased sharpness in all but two of them. The two Sebenzas.
Well over thirty hours went into these efforts using primarily the Sharpmaker rods. It took quite a while to remove that much S30v with consistent precession and care. I figured I'd develop my technique by sharpening the less expensive knives before tackling the Sebenzas. Cosmetically the Sebenzas look fine but their cutting edge appears and feels ragged when compared to the Kershaw, Spiderco and Benchmades. The Sebenzas also seem to loose their sharpness faster than the others. I was attributing this to my imagination since all blades now have the same 30 degree edge bevel with a 40 degree microbevel. I was contemplating getting an Edgepro hoping that it would help me get the edge I was looking for.
The fit, finish, shape and quality material of the Sebenzas are excellent but their edge taking and holding ability is frustrating me. Since I am inexperienced in sharpening am I just a dope or is there anything I should be doing that I am too stupid to be aware of. Is there any technique or method that will allow me to get the same edge on the Sebenzas that I have on the other S30v bladed knives. Thanks. OldDude1
If it is soft then it should be easier to sharpen.I'm pretty sure your sebenza issues are a result of the CRK heat treat, as I recall he leaves his s30v a bit soft, and since you have sebenzas... buying an edge pro shouldn't hit your pocket book too hard.
