I just thought he was grouchy because all his knives are hidden in a safe and he never gets to enjoy them
They are all from 3 or 4 mm thick stock and they all have a depth of scandi grind which is 8 to 9 mm....doing trigonometry maths this means that the edge on a zero grind is around the 25 degree inclusive mark.
This is way too thin for 01 steel or any other steel hardened to around 58-59 Rc... the edge simply rolls and if hardened higher it like as not would probably chip.
The best edge retention for these blades is by giving them a micro bevel and from my experience my best/most long lasting edges come from using the Sharpmaker on the 40 degree inclusive angle for the ceramic rods.
Spyderco tested a lot of angles before putting the Sharpmaker out on sale and found 40 degree inclusive to be the ideal for most steels and I have to say from my experience trying all sorts of angles I cannot contradict them.
However if you are looking at Scandi grinds for Bushcraft use on the basis that field sharpening is the reason for choosing them as the consistancy of using the grind for a zero edge makes field sharpening "easy"....and now find out that to make the knife perform well you need to sharpen using a micro bevel...the whole reason for choosing a Scandi design has to come into question
And for those who want to say my knife works perfect on a Scandi zero edge...well check out the Ray Mears DVD on sharpening a Woodlore....I think it is available on U tube...Ray does a zero grind and then strops his edge for 50 strokes which will certainly convex the edge somewhat...and then he runs it along the window of a Landrover at an angle which is not a zero edge but more like the 40 degree inclusive you would get from a Sharpmaker....so if Ray is putting a micro bevel on his knife and he designed the Woodlore and probably has more user hours clocked up than most of us...it is unlikely that what I have said is wrong...
One thing I should mention, I will not be modding the BOSS to give it a convex edge prior to the competition. This test is to see which one I like better in its "natural" configuration.
While a RAT 4 may be more similar to a BOSS, similarity isn't the point here. The Bravo 1 is the best bushcraft/survival knife I own and I want to see if I can one-up it. The RAT 4 and Fallkniven F1 and S1 already lost in previous field tests, so this is just a one-on-one competition.
Here's a preliminary list of test factors I'll be considering:
Bulk
Cutting geometry
Balance
Ergonomics
Ease of sharpening
Edge retention
Corrosion resistance
Notching
Batoning (with cutting edge)
Batoning (tip-first)
Chopping
Slicing
Prying (light only - this isn't a destruction test!)
Stripping (bark and branches, not shirts and underwear)
Firesteel striking
Any ideas for additional tests?
...This is why I'm such an advocate of the two-tool philosophy. And historically, the two-tool philosophy is borne out....(snip)... Get a big tool and learn to use it, use it for everything, including the detail work, as much as possible. (snip) Then get a small blade of your choice for the little stuff. Most of all, pick the tools that work best with your style...
Because INFI doesnt chip, its easier to sharpen since youre not grinding steel away from the edge. See what I mean go to Bussecombat.com and click the INFI tab.
What? Mike Stewart will send you a new blade to you on the spot if you actually manage to break a Bark River. His warranty/customer server is superb.Not as good as Busses, they have a lifetime warranty against manufacturers defects. The only company with a better warranty than Busse is Rat Cutlery, which is impossible to beat, even by Busse.
Bark River's website is probably the most outdated and bugged site in the history of the World Wide Web. Nobody updates it... If you want reliable info on Bark River concerning their policies, you need to pick up the phone or deal with them in person. (or read the Bark River's message board).I'm going by the warranty page and what it says, not from experience.
If one really wants a real tough Bushcraft blade, then the Bark River Aurora is much better than the Bravo-1-- and better than any Busse, for that matter.
I'm talking about Bushcraft knives here only, and the Aurora was built and designed from scratch as a pure Bushcraft tool by experts. Hold and use one and you'll immediatly notice that. The Bravo-1 was not... And Busses are sharpened prybars built to take any abuse you throw at them and they excel at that, but they are no Bushcraft tools. I love both brands, but I roll by the "use the right tool for a given job" school of thought. Just my 2 cents.any other broad sweeping opinions you'd like to enlighten us with?![]()
Many Busse's are sharpened prybars, but not all of them are.
