I thought about lanyard holes too.. I'm going to use the blades for a while before I go hacking them up.
Zieg, the stainless and carbon both reached the same level of sharpness for me. I'm not really comparing them fairly because the HD is 30-odd% thicker than the SS one I have. I think that affects cutting characteristics more than anything. The thinner blade slices cleanly and really glides through the cutting media. The thicker blade, which just happens to be carbon in this case, still cuts and slices through, but you can feel more resistance and it fells less "gliding through" than it does forcing its way through.. if that makes sense.
I do feel as though I had to strop teh SS blade more than the carbon to reach a comparable level of sharpness however. but it also seemed as though the thinner SS blade didn't really NEED to be as sharp either.
The real test will be when I can compare SS vs CS blades of the same thickness.
Hey, I didn't make the video!
I just thought it showed how the knife could be if it was the only one you had.
If you keep hitting a Mora on the butt of the handle, you will loosen the blade or crack the plastic handle. It has a 3/4 length tang.
What model is the bottom knife??
