The blade will release sooner if pressure is applied as the corners of the bar/blade interface get near the edges. As for screws and monkeys; It is true that not all monkeys can or should use all tools . You are assuming that the lock bottoms out in the cavity in the blade and that is not the case. It is a wedge fit making contact front and rear but not at the bottom. So changing the depth of the lock by removing some portion of the total depth will not change the looks of the bar in the open position. The front portion (depth) likely will affect the closed bar height but that doesn't need to be removed to affect the release of the blade. It is also possible that reprofileing the cam portion of the blade would be the best option. Again, because it doesn't have screws, you can't fully assess the operation. If all of your Persions require the lock bar to be "fully" (or more) compressed then there would appear to be a design and/or manufacturing "issue".As for the "others" am not sure what you are saying. I'm not sure I agree with your idea that pressure on the blade would change the release depth but if the blade released sooner, the distance between the bottom of the dent and the bottom of the lock well would be even greater. As for screws, don't think I'd ever monkey around with modifying lock engagement depth and they'd sure as hell ruin the looks of the knife.
Paul
