- Jan 16, 2000
Hello again people, sorry i havent posted in a while, but now i have some free time. Ok, yesterday, i was quite bored out of my mind, and i was looking over my knives, and it just sprung into my mind, the thought of lock designs, and which is truly the best, or will fare the best if given a certain test. All the knives below recieved the same test, this was clamping the blade in a vise, between nothing but the steel teeth on my vise, and then putting alot of weight on the handle. Let me first start off saying that i am 5'8in. tall, and weigh 216lbs. And this test was strictly for my own personal info, i know an exact weight wasnt observed, but in all honesty i must say i tried to give each knife the same amount of weight-or some knives that busted before alot of weight. I was standing, and put both hands in a one-over-the-other-format. And aplied pressure to the knives handle until, well, you'll see the results below.
KNIVES THAT WHERE TESTED.(Spyderco endura-new model with metal clip, and zytel handle, CRKT M16-dagger blade, w/zytel handle, BM710sbt axis lock, REKAT Carnivour-newer model w/release slide button on the handle, COLD STEEL tanto tip large voyager-4in blade, and a BM750 pinnacle/mono-lock-newer model, with thinner and refined lock bar.
ENDURA-this knife was horrible, it was the least strongest lock of all, i gave 2 weight thrusts with my own weight-it broke on the second thrust-the lock bar/cam cracked, and the pin that holds the lock spring bent severally.
CRKT M16-dagger blade/zytel handle-i honestly really liked this knife, and thought it would be much stronger-boy was i wrong, given the same test as the endura, this knife took more pressure, and about 3 weight thrusts, but i said, oh my god-this lock crumbled horribly, the whole lock bar bent out of shape, and bent the zytel scale so much, and the lock bar literally bent out of the handle.
BM Axis lock MODEL 710sbt-this lock was
totally killer, this lock is so damn strong, i gave it 5 hard weight thrusts-TAKE NOTICE THAT MY VISE IS ON A SMALL-BOLTED TO THE CONCRETE SOLID WOOD BENCH, AND THE VISE IS UP TO MY WAIST. Therefore i can jump slightly and bare all my weight on the knife. I really tried to make this fail, but it just would not budge-i next got a rubber malet/sledge hammer and struck the handle with alot of force-it did not budge.
REKAT Carnivour-this was an incredible knife, great lock, and the testing was very similair to the Axis lock's testing, with all my might, i could not get it to budge-even with the malet. I must say though, the rolling lock on the rekat did bend alot more then the axis lock did-while giving pressure with my weight-but it never failed, nor the axis lock.
COLD STEEL VOYAGER-this knife was stronger then the CRKT, and the Endura, but it took about twice the pressure as the CRKT did, but it failed, and very similair to the Endura's failure-but on the Voyager, the blades lock surface/cam cracked-the endura's spring/lock bar notch got sheared.
BM Pinnacle model 750-this knife is a winner, it took as much pressure as both the Rekat, and Axis, but it did bend slot more-the lock bar bent outwards, but never failed, and it withstood the rubber malet-this knife is very solid.
Upon closer inspection, the axis locks pivot pin was slightly bent, and the axis bar was dented about 1/16in, and the axis lock had some back and forth play to it, but was still able to function-this will be my tool box knife.
The REKAT's lock was also dented, but the dent was deeper, and the REKAT had alot more play-the pivot pin on this knife was bent considerably, and the knife doesn't pass the spine whack test-OH, YOU THOUGHT I FORGOT ABOUT THIS TEST, NO WAY. The rekats passes some whacks, then fails others, the axis lock passes all whack tests.
Now, the Pinnacle did probably the best job, it held strong, it passes the spine whack test every time, and guess what, it has zero back and forth play, although the pivot pin was bent slightly, this knife was the best in terms of "survive ability" but my choice for the best lock would be the Pinnacle, or the Axis.
I know i am a real jerk for doing such test to knives that are so great, but it was done for my own personal rants, and i though alot of yall would want this info. Know i have to get another Axis lock-there goes my paycheck, lol...
"for future shall not bring freedom..but not the sight that man sees, harvest your freedom, and make a future..for no one is here to protect your fate, and tame your dreams-freedom, it's in the air..."
