Who rattled the troll thread to attract all here?
Wait...I'm confused...who's rattled in this thread?
I have a question related to a prior post - Can an RMJ or similar hawk really chop through the hardened shackle of a padlock without major destruction to the hawk?
TA-DA!
I will be using the blade to chop through the shackle. I wish I could get to it sooner but I'm guessing tomorrow evening or Sunday will be as soon as I can due to work.
After I chop through the shackle, I will show you how the edge holds up under repeated blows against the body of the lock as well.
- I may try the blade at some point on the shackle, but I make mine with a decent wood-chopping bevel that'll cut thick sheet metal and still hold a working edge. I don't know that it'll be pretty trying to break a shackle with it. The VTAC has an edge more like (not just like, but more like) a cold chisel, and I could see it doing the job. Mine are aimed at a bit of a different direction.
You would definitely want a different shape on the edge if you were planning to chop steel with the tool. I wouldn't expect any tool sharpened to chop wood to be able to chop steel unharmed. Bolt cutter blades are hardened to cut steel. But they do it with pressure not impact. Put an impact on steel that hard and it will chip or crack.
A tool has to be designed for its purpose.
