- Jan 24, 2012
Mine is solid
And you guys are nuts , skelonizing a knife does not make it weak, having a stick tang does not make it weak. It's about how the tang is transitioned that makes it strong. How it Carries stress throughout the knife. When it hit it and it vibrates, how that vibration is distributed.
Yours just had a problem, maybe because that's an area of the blade that had been cut on it had a little micro crack or something that when hardened spread further; idk? Just an uneducated guess
Everything about this post is dead on accurate. Cut outs don't make a knife weaker if they are done correctly, by this there should be no sharp transitions. Squared off transitions lead to breaks. Rounded off, smooth, and slow transitions are almost as strong as a solid tang. They will by design be slightly weaker but they are strong enough to not see a difference in over all durability.
My BK16 has sharp transitions which is why I wont be batoning much with this knife any longer. After the recent BK16 bend thread I ripped mine apart and did a really good inspection of the knife. The design of the knife is flawless the execution of the design does leave something to be desired imo. If I want to baton some hard nasty wood I will grab one of my ESEEs or Swamp Rats. If I want a knife I can do detailed wood working for long periods of time I will grab my 16 because the handle is just that comfortable.
