- Jul 21, 2016
I got the 110FG.... It's awesome...
Deere Man, do you work or have worked for John Deere?
Not that this will sway your opinions either way, but here’s my 112 in “Oak”. When I first received it, I thought the same thing. It doesn’t look like oak to me either, but I still love the knife. As you can see, it gets carried and used regularly. View attachment 1056083
I could easily see it as a red oak darkened by the laminating process because I have seen red oak that looks like your beech sample. There are so many factors that could contribute to that grain structure. I'll try to get some pics of some this weekend or maybe if BP will show his thinned 112. It's a little more radical than yours but shows the same grain pattern.
View attachment 1056145 It does kind of look like Black Oak or White Oak, but I defer to your education over my google-fu.
Here’s a sample of Black Oak...kinda similar?
I was wondering the same thing about that same oak 112, and almost ordered one a week or so ago. I ended up deciding against it because I wasn't really interested in the 5160 blade at this point in time.
To determine if the scales are laminated, look at the edge. If laminated, you will see the horizontal parallel lines of glue where 4 or 5 layers of veneer are glued together. If solid, you can tell where dark & light areas follow through the whole thickness of the slab.
My first photo shows two ebony handled 112s, solid on top, and laminated on bottom. The second pic is the stock pic for the oak 112. It looks like oak in the pic, and does not show the glue lines on the edge from what I can tell.
I appreciate different types of wood too, and I don't think I'd be overly satisfied with laminated beech if it was advertised as solid oak. The new Bucks affiliated with Taylor Guitars have solid ebony, with no price increase.
Laminated wood is more stable and durable than solid wood in sudden changes of temperature or humidity, and maybe less prone to shrinking or cracking in some cases. We take this into account on something more thin & fragile like a musical instrument, not so much with a knife handle unless you're regularly in extreme conditions or salt.
Now I'm wondering about the 55. I was under the impression that its scales were real walnut. I'm going to try to find one in a store to look at. I do buy knives online, but if you care about the wood, it's a big advantage to be able to look through a handful in a retail store and pick the one you like best.
JT
The Ebony Bucks are on their website. Just got mine yesterday, looks great!!
Nope. Many years ago when I joined this forum, my other hobby was collecting John Deere 1/64th scale farm toys. Deere Man was my handle on a farm toy forum so I just used it here as well to keep things simple. I eventually gave up the toy collecting because I spend all my money on knives and multitools.....
I'm a wood guy but I'd pick dymondwood of done right. The problem I have with it is when it gets sanded through like the top knifes scale in Buckshacks pic. The laminates are thin and easy to cut through. I thought about making my own lam wood scales but I just stabilize my wood instead. Laminated wood is better for rough use because it is in essence, not wood anymore.
Wouldn't boiled linseed oil correct the damage??
Definitely laminated on mine.
there would be no end grain on dymondwood.
OK, to me it looks like moisture has gotten into the wood or under the top coat of laminate...
So if you sanded the rest of it would you need to treat the grips with something?
free photo hosting
