Bumping this thread, to add an update.
( 08-FEB-2023 - EDITED TO ADD: This knife is still closing consistently, as hoped. Been carrying it in-pocket everyday without issue, since fixing it as described below. )
Was able to get the knife closing more reliably and STAY closed, by doing some sanding to take just a couple thousandths' thickness off the ricasso portion of the blade. I'd commented earlier, the ricasso's thickness was actually 0.002" or so thicker than the accomodating space in the bladewell of the knife. So the ricasso was being pinched by the handle itself upon closing, which added a little too much resistance against the closing pull of the spring. That was leaving the blade tip exposed above the handles on occasion, at one point slicing through the interior fabric of my jeans' right front pocket.
The 'fix':
I had some PSA-backed 180-grit SiC sandpaper on hand at home. I laid a portion of that down at the edge of a granite reference plate and simply laid the blade flat to the sandpaper, sanding in linear passes perpendicular to the spine of the blade. It left sort of an 'as ground' finish on the flats of the blade, which doesn't look too bad. And after taking it down to 0.115-0.116" thickness from previously about 0.118", give or take, it started 'walking & talking' more like I expected, as compared to my other Buck 110/111/112 folders, in terms of the feel, consistency and sound of the closing snap. Brought it back to a condition where I'm comfortable putting it in my pocket again without worrying too much about the blade tip being exposed above the handles. I used a little bit of Simichrome polish by hand to buff up the 180-grit finish on the ricasso for some extra insurance. Pics below show the ricassso portion after sanding and before I lightly polished with the Simichrome - and the 'as ground' look of the 180-grit finish on the blade (3rd pic).
In all, I'm glad I didn't have to fiddle with the pivot itself or the interior of the bladewell to open that up a bit. I can happily live with the result as it is here.
