420HC Generally considered the king of the 420 steels, 420HC is similar to 420 steel but with increased levels of carbon (HC stands for High Carbon) which makes the steel harder. Still considered a lower-mid range steel but the more competent manufacturers (e.g. Buck) can really bring out the best in this affordable steel using quality heat treatments. That results in better edge retention and resistance to corrosion. In fact, this is one of the most corrosion resistant steels out there, despite its low cost.
Yes jun, there is. Buck switched from 425 to 420 because the former was more wearing on tooling and stock cost. The vanadium and molybdenum elements probably did it. Then there were some manufactoring differences in the steels which showed up when they were mirror polished. DM
Thanks boz, and welcome to the Buck Forum. DM
I have several Buck folders, including a brass and ironwood adorned Ranger. After whittling, camping chores, trimming modeling plastic, and terminating cab tire (HD extension cord cable) I've made the following observations about Buck's 420HC and their knives in general:
-It sharpens easily
-It will take a pretty good edge
-It's very corrosion resistant
-Excellent fit and finish, especially on the Ranger
-Abysmal edge retention for a knife that costs more than $20
I've also noticed something about the discussion about edge retention. You'll see people that have old Bucks made from 440c say stuff like 'my old buck could make it through X deer before noticeably dulling. My new Buck won't make it through one deer'. Proponents of 420HC will just say 'it's great' without giving context.
Badhammer, I don't remember how many cable ends I terminated before my ranger went dull, but I got more done with my $12 Mora craftline Q than my $60 Buck.
I completely gave up on whittling or making fire sticks with a buck and I completely gave up on using it for trimming plastic modeling pieces. I'm actually using a cutco paring knife for that now because the edge retention is far superior to the buck bantams my son and I tried to use.
I think your question is insincere, and you'll likely dismiss everything I'm saying without considering it, but I know what my experience has been.
