OK, I believe Jeff. I'm an engineer who works with expensive metal products. Let me start by saying that engineers do not know everything. I am amazed and horrified at the idea of hitting every blade against a bolt. Just do it once and take a picture. I'm not saying that they didn't do it. My fear as an engineer would be that some knives develop invisible damage that would reduce their lives down the road. Modern engineers would never allow this. But it worked for Buck. A non-engineer started the company and developed a test that he liked. The test is impressive. It apparently did not cause invisible damage. The test was "indicative of a high level of testosterone." (I have self censored my original wording but I am sure you get the drift.) It established Buck's reputation. Thus the capitalistic system and a gutsy knife maker allowed a company to grow and thrive in an area where the customers would have been very unforgiving of bad knives. This is a great story: practical hands-on design skills, gutsy testing and an amazing belief in the product.
The engineer (who I have known for 30+ years) started in 73. So we were still hitting the bolt then. We would give it a good smack on the spine and if the edge chipped, it was rejected. We didn't cut through the bolts. I'm sure bolts were re-used. I too think we stopped when we went to 425mod, but not sure on that.
Non-believers can poo-poo it all they want.
It makes sense to me that the testing stopped when the blade steel was switched from 440C to 425M. 440C has twice as much Carbon and can be hardened to a higher Rockwell C rating.
At least you got the bolt cut in half. nice. lolBeing a huge Buck Knives fan and collector ,I once took a 440c 2dot 110 and did my own test ,I wanted to cut a bolt in half myself ,I used a 2 dot I won real cheap and it was not new or even close to new when I started with my test ,it was given a fresh cover edge I like to put on 440 c Buck 110s.
I completely ruined the knife I will admit my stupidity,I just didn't understand what Buck did with their test,until some chats with Joe Houser set me straight.I actually cut the half inch stainless bolt completely in half ....Which is NOT what Buck did in their edge tests.
When I was done my test the knife was not useable or repairable and the bolt was in 2 halves.
I absolutely believe Buck used this method to test edge hardness,Joe has confirmed it and also Jeff Hubbard as well.We need to remember they never had all the high tech things they use now to test edges.They did it the old fashioned way.
I was 3/4 of the way through the bolt when I broke the lock bar,and I had to use several sections of the blade ,Also the first couple whacks barely rolled the edge on that ol 440c,but then I got aggressive.
I've put my 110s against many fixed blades at deer camp,and they hold their own everytime .
Boru13 - you're my hero.
I will be the first to admit that the Buck picture implies that you can just go around cutting bolts in half. Now we know what we always should have suspected - don't do that.
