This is the best way to store your knives and gear, and is a great investment. Just throwing it out there. GO WITH A HARDIGG BY PELICAN.
This is the best solution to your storage without buying a heavy safe that is bolted to the ground. This will cost you 150-170 dollars.
http://www.ebay.com/itm/Pelican-Hardigg-Military-Case-18-75-x-18-88-x-12-19-w-pre-cut-foam-/251757937982?pt=LH_DefaultDomain_0&hash=item3a9df1453e
http://www.ebay.com/itm/Hardigg-Pelican-Case-Heavy-Duty-Military-SEE-PHOTOS-/231408360583?pt=LH_DefaultDomain_0&hash=item35e1035c87
This is what recommend to use. Waterproof, durable, and air tight.*** For all storage of outdoor gear and valuables. The foam can be cut with any serrated kitchen knife to your needs, removed as well. slits can be cut in the foam in the lid and bottom foam to insert flashlights (AAA Maglights), tools (Wrenches), and small knives. VERY durable case, completely waterproof, THICK plastic, secure metal clasps. The only thing missing is a way to lock the box up;
http://www.homedepot.com/p/National-...vZc26wZ1z0ydp7 (U BOLT)
***Just two sets of these; drill holes, use modified U bolt trailer plates and lots of gorilla glue/two part epoxy (the trailer plate to the box) for a master lock. Place where ever you would like on the box for the best convenience and security.
DESSICANT*** Use at least 60-100grams, this will repel water and keep your box moisture free.
http://www.ebay.com/itm/Gun-Safe-Rec...-/230955640098
You metal goods are secure, easily moveable, moisture and air tight, controlled and safe. You will never worry about them again.
For your loose folding knives and small objects (wrenches, clips, screws, handles) Use bags of some sort to keep them from banging around and scratching. Either ziplock or some bag that is the perfect size.
(Bass pro/plano -- Or waterproof survival boxes in the camping section of your supermarket work great as long as you buy plastic bags that are the same size as your knifes ~ The best way to do this I have found is to buy some online or go to a pipe shop. They carry bags in all shapes and sizes with different patterns on them for organization. Keep 'em oiled with Hoppes Weathergaurd.)
Bags:
Cheap, disposable and will keep your knives from scratching each other.
For bigger storage needs:
http://www.ebay.com/itm/HARDIGG-MILI...item2ecbbf3631. You will need to find another listing, this one is old and just for reference.
Hardigg will last you the rest of your life. Get a big one, your collection of survival equipment and valuables will grow.
I use one of those for my EDC knives. I can put 16 large folders in it. Thinner knives I could fit 24 in there, shorter knives that could go up to 36 in there. This particular case model was fairly popular and they made a carrying case that would carry 4 of these with one handle, so you could carry up to 144 of your favorite knives with you.
My ten dollar storage placed in the sock drawer works fine for me.
You both could store your folder boxes in one as well. Looks like you both have it figured out pretty well, just an idea? :thumbup:
