Alright guys, slow start and nothing to get excited about...this is mostly a scrap build. I do want it to be fairly heavy duty. Starting with the base, to grinder build, to improvements and embellishments.
Found some workable junk in the pile, including some farm plow parts I dug out of my yard and this old guy with a blown hydraulic pump:
It yielded some good stuff I will make use of.
Had this 1" plate laying around, figured it would make a good base.
The 2x4 tube is 1/4" thick and has some holes that will come in handy later. Solid steel wheels are from the jack and the axle was yard gold I literally dug up.
Originally thought Id put the front on wheels, but for me stability is key (as much as possible when you are lipstickin' a pig) These wheels dont lock and id have to fab up adjustable feets.
Now im thinking about going over the top of the base plate with the axle, so it has to be tipped backward to move around. All else fails, I can rig up a fork lift bracket situation.
Some 5/16" thick bars for table support. This height should line up the tool rest with my belly button.
One thing holding me up, is that I dont have a big enough plate for the top... unless I want to stitch these 1/4" plates together...which I may do.
Or maybe just do some thick strap for mounting and expanded metal the rest instead.
Perimeter of the table is a 3/16" rec tube that should give me plenty of apron to possibly stick stuff to later.
If this wasn't exciting enough, here is more junk
Nice thick plate for platen and another plate for a tool rest. Rusty gold there is solid square for the platen arm.
Few ramblings:
-I do have a real thick aluminum disk that I could cut a platen out of..any drawbacks to using alu vs steel?
-Is it OK to run the grinder wheels on the threads of the 1/2 bolts? (they do have a sleeve in them, so I would think it doesn't really matter. I happen to have a bunch of 1/2 carriage bolts.
-Does my wheel setup look kosher? Im no engineer lol.
Any advice or criticism is welcome. Gonna start the more fun stuff soon.
