The welder was a harbor freight 90amp and it was awful. It actually got too hot during this project and i couldnt screw the nozzle off to clean the tip or change it or anything so i got my money back. I will buy a lincoln before my next project. With that HF welder, i could get decent welds sometimes, but most ended up like the one on top. It literally had only two power settings, and this was at max power. Part of it could be me being inconsistent, but i swear sometimes it would just pop around for no reason sometimes. I mean i could one good weld and then immediately do another and it would just pop like crazy and i couldnt get a bead started worth a crap.
I will switch off the element before reaching in, but of course that has a human element and i cant be distracted or i might possibly forget. With the system unplugged i did reach in with my tongs and try to bump the coil and it is difficult to do accidentally i think.
I am finding this oven to be pretty sensitive. It has been running awhile and it hasnt achieved the +/- 1 degree at all. It tends to run a little hot. It may drop 1 degree below what it is set for, then the element kicks on and it can go as high as 10 degrees over and drop back down and hover around 3 or 5 degrees hot a bit and then either slowly drop some more or jump up about 10 degrees.
Still 1000x better than a coffe can forge and plumbers torch!
