eswartz
Basic Member
- Jun 29, 2005
Late to the party. I can't believe I missed this thread until today. Usually I am all over reading about Bulldog knives.
I have a number of these Bulldog Whittlers, ivory, pearl, stag, big, little...
I also sand down the coping blade if it is too pointy. I looked at your picture for about 15 seconds before I noticed your adjustment.
As with any knife I have with blade play I will tighten it using the following method.
(Tightening is easy, Sanding down the pins flush is the hard part)
1. Place bolsters between two pieces of wood and put in vice.
2. Tighten on vice. You can go gently and test, or overtighten and loosen slightly.
3. Check play. If too tight, pry apart until adequate talk is established. I use a screwdriver covered in electrical tape.
4. Sand down pin exposed pins until flush. 220 (pin only), 320, 400, 600, 1000, 1500, 2000, paste polish.
It usually looks pretty good at this point. You may still see the pin, but it usually disappears.
