Leuku pattern bushcrafter
This has a slightly narrower blade than many of my leuku pattern bushcrafters, with a good belly curve and a bit of filework on the top. Being 1/8 inch L6, it's a bit stiffer than the 15N20 models, and will hold up to heavy batoning well. The blade - at 5 5/8- is long enough for some thick splitting, and with the straight spine will makes and excellent draw knife.
At 4.25 inches, the handle is full sized and easy to hold onto, but short enough to get your palm behind for push cutting and stabbing cuts with a safe grip. The shorter handles like these are also very good for working in heavy gloves, where getting the butt of the knife into the hollow of your hand helps with the grip.
* OAL 10 1/8 inches
* Blade 5 5/8, 1/8 thick L6 convex ground. Forge finish buffed out then blued along spine and tang.
* Handle- ipe scales, blued steel pins stainless lanyard tube.
* Expedition sheath with fully adjustable hi-lo belt hanger and lanyards holes at the bottom.
$125 shipped USPS, paypal or postal money order preferred.
* OAL 10 1/8 inches
